2005 E46 Imola M3- correctional
Discussion in 'Show and Shine' started by premshine09, Jun 28, 2013.
  1. premshine09
    premshine09 Jedi Nuba
    Hey there folks,
    Extremely backed up on write-ups but I have the free time to put together this near 30 hour correctional on a heavily tracked E46 M3. We decided on a full correctional with Opti Coat 2.0 application for a durable coating of protection. This is the 7th E46 M that i've had the opportunity to fully correct, I enjoy every one!
    Correction was performed via a PC, Flex, and the Rupes 21 with various foam pads- even a surbuf pad here and there. M105/ 101 and Sonax PF used.
    The entire front end had been cleared a while back- bumper, headlight gels, mirrors, behind every fender well, rockers, pillars, and on the front fenders as well- the aim was to keep as much as possible and restore them via polishing and then shortly after using opti to layer on top of the film to create an incredible layer of durable protection.
    Before:
    Film was heavily swirled and marred
    Headlight gels and trim below headlamp were very, very yellow and faded- these were removed
    dull
    Wheels needed to be de-ironized
    tips needed attention
    good shot to see the before condition with all the defects
    First up was a full decon wash- pre=spray with APC on the heavily soiled areas, Sonax FE working it magic here on the wheels
    The tips were hit with IronX + 0000 steel whool and later polished with P21s soap
    Wash phase- thick suds with chem guys maxi sudz + citrus wash + Dawn to strip
    Correctional process: approx. 25 hours
    Before pics of the defects:
    Hood
    50/50 in the hood
    Right front fender
    Pass. door
    Mid to lower section of door
    Lower section
    Panel area right before rear passenger tire
    upper rear pass. quarter
    Fender lip over rear pass. tire
    Defects very visible here in natural light!!
    Roof line
    driver side rear quarter- near rear tail light
    50/50 on the rear bumper- this section was a PITA to clean up...always is on this model!
    Top portion of rear bumper
    50/50 on driver side door
    Front clear film on hood after- much more clear
    Between compounding/ polishing/ finishing steps the M was brought outside and washed down
    The body was wiped down one more time with CP Eraser to ensure all oils etc. were removed
    BEFORE Opti app.
    After correctional shots- before Opti Coat app.
    Hood
    Front fender
    pass. side door
    Mirror
    Near the rear tail
    Deck lid
    near driver door
    Lower driver door
    Driver door
    Driver fender
    other half of hood
    Tires were dressed with Opti Gel tire dressing
    Opti Coat 2 up and ready for application!
    24 hours after application of Opti Coat - pic time!
    GLOSS
    [​IMG][​IMG]
    Thanks for looking all!
    - Dan K.
  2. vasaline
    vasaline Two Bucket System Washer
    Looks great! What was your process for correcting the clear film?
  3. premshine09
    I didn't have much luck with Menz 2500/ green foam on a test spot- switched to Sonax PF on a green pad and saw 80 %- switched to orange foam and cranked down the speed a little and voila, perfect
  4. supercharged
    Holly cow! I'm speechless, this is amazing!
  5. stingray23
    stingray23 Jedi Nuba
    Great job, Thats my favorite ///M color.
  6. maxepr1
    maxepr1 Jedi Nuba
    Nice work! Paint look deep wet!
  7. Socal Brian
    Superb work Dan!
  8. Pureshine
    Pureshine DB Pro Supporter
    Wow!!!!
