2-step polish on black Range Rover
Discussion in 'Show and Shine' started by RaskyR1, Oct 9, 2012.
  1. RaskyR1
    RaskyR1 Jedi Nuba
    A good client of mine had scheduled this job for a 1-step polish a while back. Unfortunately he had to drop it off while I was not there (I was working at my regular job) as he was heading out of town for a few days. I stopped at the shop over my lunch break to check it out and to pull it inside....immediately I new a 1-step was not going to get this thing to where we wanted it to be and I contacted him to discuss the issues I was seeing. There was heavy swirling and some sort of chemical staining/oxidation all over the vehicle (likely from touch-less washes). One thing I really wanted to do was utilize the MF pads ability to get it close to edges on this vehicle. Foam pads often have a rounded edge which prevents them from getting in real close like MF pad can. This was very important around areas like the door handles and the top edge by the windows as I has to cut away the oxidation and staining.
    Before pics (I was pressed for time on this job so the pics are limited)
    Close up of staining
    Paint looking dull and stained
    Sonax FE doing work!
    Cropped pic to better show staining/spotting
    Paint wash washed with CGCW followed by IronX and TarX. Surprisingly IronX removed a lot of the staining that was on the paint! :)
    50/50 shots. Correction was achieved using D300/MF on the GG6, and Sonax Perfect finish/Tangerine LC on the GG6.
    It was getting dark when I finished and the owner was on his way so the only lighted after shots I had were the 50/50 ones. :(
    LSP was Blackfire Wet-Diamond (2 coats). Trim was coated with 22ple. I actually did do a full interior on this as well, but chose not to take pictures as I was pressed for time and it wasn't too dirty inside.
    Finished pics
    Thanks for looking,
    Rasky
  2. kakeuter
    kakeuter DB Forum Supporter
    Nice work Chad! Can't wait to start trying 22ple.
    -Kody-
  3. RaskyR1
    RaskyR1 Jedi Nuba
    Thanks Kody! :)
  4. 911Fanatic
    Very nice Chad. Looks mint. What are the differences between Opti Coat and 22ple?
  5. Chaseme
    Chaseme DB Forum Supporter
    This is killer again Chad.
    I hope to use 22ple soon.
  6. kaisernaut
    kaisernaut DB Forum Supporter
    Look good Chad!!
    I used the 22ple the other day on silver g35, all I can said its the easiest coating to apply. It also give the car a glossy wet look too it. In term of durability it's around 18-24 months.
    Tuan
  7. RaskyR1
    RaskyR1 Jedi Nuba
    I can only comment on application, looks, and feel right now...I haven't seen any long term testing yet, but as Tuan stated, it supposed to last 18-24 months, where OG is permanent. In terms of application, looks, and feel, 22ple is better IMO. For long term durability I think OG is probably still king...only time will tell. ;)
    Thanks Chase! Let me now how you like it when you do.
    Yup!
  8. Pureshine
    Pureshine DB Pro Supporter
    Looks great.
  9. rwisejr
    rwisejr DB Forum Supporter
    You knocked another one out of the park !!!!
  10. GDAL
    GDAL Super Moderator
    Amazing work!!
