1Z Vinyl-Rubber Protectant spray (Tiefenpfleger) - preferred application?
Discussion in 'Car Detailing Product Discussion' started by EbbeJ, Jan 4, 2014.
  1. EbbeJ
    EbbeJ Jedi Nuba
    Hi Guys,
    As in the title, how do you guys like to use the Einszett Vinyl-Rubber Protectant?
    I just bought some to try it, as it states that it withstands high temperatures and weather in general, so should be a better all-round solution than 303 aerospace. Thinking mainly engine plastics and tires.
    Kind regards,
    Ebbe
  2. detailersdomain
    Ebbe,
    We use it on tires in the shop it works great much like Swissvax Pneu something we use to use quite a bit, goes on easy and looks nice. A nice matte finish, make sure you clean your tires first.
    Phil
    EbbeJ likes this.
  3. detailersdomain
    On the engine its nice but you will need to wipe down the excess - spray on let dry then wipe the excess off.
    EbbeJ likes this.
  4. EbbeJ
    EbbeJ Jedi Nuba
    Thanks Phil, I'll give it a try.
    Kind regards,
    Ebbe
  5. detailersdomain
    sure thing report back, if the tires or rubber is dried out you may need multiply applications.
    EbbeJ likes this.
  6. EbbeJ
    EbbeJ Jedi Nuba
    Will do, thanks :)
  7. Michael@nextzett
    Michael@nextzett DB Certified Manufacturer
    Just want to confirm what Phil advised. If the surface is dry, multiple applications will be needed initially but after that you'll need to use it less and less to maintain it. It leaves a sealed finish so it can hold up well against weather and sun.
