1Z einszett Paint Polish 'Lack Politur'
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by LAV86, Dec 7, 2010.
  1. LAV86
    LAV86 Two Bucket System Washer
    My car is a 2010 bmw 535xi and the color is a metallic black, and i just wanted to know if this polish will remove very light hair-lines scratches from the cars finish?..with this polish i want to use the UBER GREEN PAD..please any info will great..
  2. slanguage
  3. LAV86
    should i use a PC or a Rotary?
  4. slanguage
    Try the rotary first, but if its not finishing down hologram free, then try the PC.
  5. CU2MIKE
    CU2MIKE Guest
    1. Have you used a rotary/PC before?
    2. Are you proficient with either one?
    3. If you've never used a rotary before, and are not proficient with a PC, you should start with a PC.
    4. Do try the Menzerna SIP, or if your car is not that bad, try 106FA.
    5. A picture of your car would yield better/more accurate responses.
  6. LAV86
    Cu2mike
    I have used both machines..
    Do I have to prime the pad with the polish prior to starting?
  7. CU2MIKE
    CU2MIKE Guest
    I give it a spritz of quick detailer if its a brand new pad. Otherwise, no.
  8. CU2MIKE
    CU2MIKE Guest
    Oh, I prime the pads if I'm using M105. Look up Kevin Brown Method, it's a technique he devised to basically (from my understanding) make M105 have a longer working time.
