1997 Lincoln Mark VIII
Discussion in 'Show and Shine' started by kustomizingkid, Dec 7, 2009.
  1. kustomizingkid
    kustomizingkid Nuba Guru
    This car is owned by a friend from another forum, I own a 98 Mark VIII. This car was pretty beat up, had a cheap SS paint job... I did as much as I could with the time I had.
    Products Used
    Megs Gold Class
    Proline Grout Sponge
    Diablo
    OPC
    CG Purple Clay, water as the lube
    Menzerna PG, SIP, and PF
    3M Wool
    Uber Green
    RB Blue, wool, and Rayon
    Autosol
    Stoner Invisible Glass
    Optibond
    AJ
    Klasse AIO
    Megs #40
    and a few other things I'm sure I forgot!
    Condition when I received it
    On with the washing!
    Pulled it in the shop... wowza!
    Clay... CG purple pulled up a lot of junk, the bar shot is after a 1x1 foot area...
    CG water spot remover in action! The car was covered in water spotting and oxidation, the WSR pulled off TONS of stuff. I'm sure it isn't meant to remove oxidation but hell it pulled of tons of junk and I wasn't complaining...
    After claying and water spot remover I taped it up for polishing.
    These are paint condition shots after one pass with wool and Menzerna SIP, there was no point in showing a bunch of pics of oxidation...
    Here is the only 50/50 I took... good stuff!
    After a full go around with the wool and SIP
    Due to the sloppy prep and body work someone nailed the window garnish with a da... I used a 75mm rayon pad with Autosol metal polish
    The headlights... typical of Marks... I hit them with 600, 1000, 2000, RB Blue and PG, and Uber Green and PF.
    Here are some afters... I topped the car with Jeff Werksatt Acrylic Jett, the hood had some nasty defects that I couldn't do anything about... but overall it looks great!
    Thanks for looking!
  2. GDAL
    GDAL Guest
    That turned out great. I bet the customer was really pleased ...:applause:
    How long did it take you?
    BTW ... how did you apply the water spot remover? Darkstar752 talked to me about this product and I really want try it on vehicle that has really bad water spots.
  3. Obsessive Detail
    Great work, that was a nice turnaround!
  4. kustomizingkid
    I used a foam app and rubbed it on, and then wiped it off with a cheap MF... then rinsed down the whole car when I was done.
  5. CYANiDE
    CYANiDE Virgin Detailer
    What are those plastic bottles called? I've been looking for 'em but I wanted an exact name.
    *don't hurt the n00b. I'm learning!*
  6. CYANiDE
    Disregard this double post. Dumb internet!!
  7. billyblooshoes
    nice turnaround! the correcting of the chrome trim piece that had the DA sand damage is pretty impressive. i saw the first pic and was like "no way hes going to be able to get that out" (no offense!). came out really nice.
  8. kustomizingkid
    The tips on fixing that came straight from Ben... I had bought his rayon pads but didn't know what compounds to use...
    I want to pick up some Dodo superfine to use with RB wool to chase out the final swirls...
    Overall I was very impressed with how much cut it had, I was planning on having to wetsand...
  9. Jedidiah
    Jedidiah Guest
    looks great!
    i love to see changes like this.. this IMHO is better than seeing some micro fine scratches taken out of a Lambo or exotic that is driven once a month .
  10. anbuzero
    anbuzero DB Pro Supporter
    i heard from a few others that CG WPR eats through foam applicators since its acidic. Dave (DSMS) has had it happen to him. I myself have applied it with a cheap MF towel
  11. kustomizingkid
    The app pretty much melted...
  12. anbuzero
    yep. i think cheap MF towel are the best bet for applying it
  13. agpatel
    agpatel OD On Detailing
    Really hand your hands full on this detail but it came out looking great. Nice work.
  14. pektel
    pektel DB Forum Supporter
    Great work, Brandon! Awesome turnaround!
    I really like the way you handled the chrome moulding too. Interesting combo there.
    Tshirts look nice too :D
  15. Misha
    Misha Nuba Guru
    http://www.detailersdomain.com/1zeinszett-atomizerspraybottle.aspx
    also check lowes or home depot garden section, i seen some there but not sure how good they work or if they provide mist as fine as this. but they were under $10 there
  16. CYANiDE
    Thanks! I'll probably grab some from Home Depot first and as I see fit I'll get some better quality ones. :thumb:
  17. slanguage
    very nice work, especially that metal trim piece. i need some rayon pads.
    what size were they?
  18. kustomizingkid
    I bought those sprayers at Norther Tool, they are Hudson brand... very happy with them...
    I used the 75mm rayon RB pads on the 75mm RB backing plate...
  19. pektel
    KK, you have 75mm ones too? I only have the 50mm ones.
  20. kustomizingkid
    Should have bought some 75mm... they are only $1...
