1 Liter Pump Sprayer
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by Cooter, Jul 27, 2008.
  1. Cooter
    I've got a couple of 1L pump sprayers. What products are you guys putting in your pump sprayers?? TAW? P21S Wheel Gel?? Give me some ideas!
  2. Denzil
    So far I only have used my pump sprayers for P21S Gel and TAW. I'm thinking about using my other Solo 418 for my clay lube but I might think of some better uses for my pump sprayer later on.
  3. Nica
    Well yes P21S TAW, Gel, ARO, Wheel Brightener, Poor Boys Bug Squash that's just a few I have on pump sprayers.
  4. heatgain
    heatgain Guest
    I keep a small pump sprayer loaded with DP 4 in 1 (or ONR) for quick small cleanups, like bird bombs.
  5. yukonon22
    yukonon22 Wax on..Wax off
    ARO, wheel brightener, Griots wheel cleaner, Adams Undercarriage
  6. Cooter
    Sounds good. Thanks for the recommendations!!
  7. FMINUS
    FMINUS DB Pro Supporter
    Basically ANYTHING that you need ALOT of and dont want to be pumping all the time.
  8. Cooter
    Great!! Thanks Phil!!!!!!!!!!
  9. JLs Detailing
    TWSS!
    I use mine for MS Super Green Stuff, CGs Grime Reaper, TAW, CGs Strong Wash, and DP 4n1 clay lube.
    A couple of products I have found that don't work that well in them are CGs Bare Bones or Adams UC spray. They are just so thick and the sprayer sprays so much that you waste a lot of it. Also Megs Wheel Brightener works much better in a traditional spray bottle with a foamer head. It makes the WB foam up really well and cling to the wheel instead of running off so quick.
  10. Cooter
    JL, have you used SGS with a foamer??
  11. JLs Detailing
    No but I did put it in my foam cannon once for an extremely dirty car. Wow did it ever foam up and clean the snot out of that car. I did it as a precursor to the actual wash and it did wonders. I bet it would work great in a foamer too.
  12. Cooter
    I think it will too. I'll put a foamer head on a bottle of the SGS and give it a try at work tomorrow night on one of those dirty ambulances
  13. Denzil
    In most applications it seems we're always using it for degreasing or cleaning of some sort but I think we can also use it for undercarriage and wheel well dressing with say Meg's HD or what have you.
    What's nice about having the Solo 419 is that you can really get into the inner wheels really well when spraying P21S Gel or whatever wheel cleaner of your choice. However, I only have one Solo 419 so I use that for getting really deep into the wheel wells instead with P21S TAW.
  14. MadOzodi
    MadOzodi Nuba Guru
    LOL!
    Thank you very much for sharing that. I was going to pour the rest of my Bare Bones into one of my 418s. I'll also transfer my WB into one of my other bottles and attach a foamer head...it doesn't degrade the seals on a foamer head, does it?
  15. JLs Detailing
    I've been using my foamer head for months now and no adverse effects. You will see a lot better use of WB with a foamer.
  16. Denzil
    So what does a foamer head look like?
  17. JLs Detailing
    Go to the bottom of the page where the bottles and sprayer heads are and you will see it.
    Meguiars Detailer Line Wholesale Prices
  18. DJBAILEY
    DJBAILEY Birth of a Detailer
    If you want more foaming action from the small hand pump garden sprayers take a hot pin and poke a hole at the top of the supply tube near the cap. Having a hole there will force air into the cleaning solution as it travels up the supply tube and spray alot more foam than normal. Just make one hole because 2 lets too much air out and the pressure goes down too fast.
    I've got 5 of these sprayers (from Lowe's @ $7) and I have 3 set up to foam and 2 for normal spray. Depends on what I'm spraying.
  19. Cooter
    Thanks for the idea!! Thats awesome!!!!
