Another problem child vehicle, sticky paint WITH additional fun for me = water spots. 22 hours plus with help from Mark Zamzow, without CG water spot remover I do not know what I would have done. WASH: GI Soap CLAY: P&S fine clay WHEELS: GI wheel gel TIRES: GI Tire dressing TRIM: GI TRV EXHAUST: CG extreme metal shine WATER SPOTS: CG & P&S acid water spot removal products applied with sponge and elbow grease CORRECTION WOOL PAD: Megs 105/GI beta with GI EVP pad prime FOAM PAD: GI exteme/EVP POLISH: Menz 106 FA GI blue foam pad JEWELLING: Menz PO86RD GLAZE: CG acrylic glaze LSP: GI Signature/Concorso The start About this point it was three hours in with the gel(rubbing and rubbing) CG gel curing Mark jewelling Getting near the finish line Sun pics
Looked like a major pain in the ass, couldnt be a worse car to have water spots and etching on! Sick work Bob, pumped for my trip out there!
Great job taking care of the water spots. I take it you would recommend CG WS remover, is it just apply to a damp sponge and wipe product onto paint till they go away and rinse off. I see you said you wanted for it to cure.
I take a damp sponge and a pea size amount of the gel and rub the affected surface with good pressure and let it dry, then rinse with a good amount of water then re-check to see if the spots will release from the surface(glass,paint etc..) the GTR took 16 applications to get the desired results. I also bought the P&S brand and it did not work quite as well as the CG water spot remover(just wear gloves!!!).
Damn, talk about impressive work. Twenty two hours isn't nothing with two guys... I bet that bill would make me fall backwards!
