'06 Lamborghini Murciélago
Discussion in 'Show and Shine' started by blk45, Feb 17, 2009.
  1. blk45
    blk45 Jedi Nuba
    A bull named Murciélago had his life spared after a fierce fight in the Cordoba arena on Oct. 5th, 1879. This honor rarely happened and was reserved only for bulls that showed exceptional courage and spirit in the arena. Murciélago proved his worthiness and was given to the breeder Don Antonio Miura. He fathered a fine line of fighting bulls that extends down to current day. The bull is the symbol for Lamborghini whose founder Ferruccio Lamborghini was born under the sign of Taurus. The symbol was selected as a powerful response to the Ferrari prancing horse, and the two Italian sports car manufacturers have competed for decades since. The management at Automobili Lamborghini have decided to baptize the latest car in the noble line with the name of a fighting bull like so many before it such as Miura, Jslero, Urraco, Bravo, Jalpa and Espada.
    The 6.2ltr V12 engine made entirely from aluminum alloy produces 580 hp and 480 lb-ft of torque. To maximize torque delivery over a broad rpm range, a variable-geometry intake system (VIS), and variable valve timing (VVT) on both inlet and exhaust camshafts was utilized. This, coupled with the all wheel drive system, accelerates the car to 60 mph in 3.6 seconds on it’s way to a top speed of 205 mph. All of the external bodywork panels are made from carbon fiber, with the exception of the steel roof and door panels.
    Process:
    Clean wheels with S100 gel wheel cleaner, the EZ detail brush, the Swissvax wheel brush and a wash mitt. Tires and wheel wells cleaned with ARO. Wash the car with CG Citrus Wash & Clear. 2oz per gallon to strip the surface of all existing wax and contaminates.
    Clay the car with Clay Magic blue clay and lube. The surface was fairly clean and only had minimal contamination.
    I had corrected the front of the car previously, before the owner had the clear bra installed, so I had already experimented with what combinations worked best for the paint and gave me the results that I wanted. The paint on Murcies is very hard and doesn’t like to correct easily. A few problem areas required a pass or two of M105 with a PFW pad. The whole car received SIP with a green German foam pad, 106FF with a white LC pad and 85RD with a blue LC pad. Prep-All was used prior to polishing and after to ensure proper working of the polishes and true correction. All of these combos were used with the Makita 9227 rotary.
    The LSP used was Ultima Paint Guard Plus. The tires received PB’s Bold-n-Bright. All of the plastic lenses and the clear bra were treated with Plexus. The windows were cleaned with SIG. The exhaust tips were polished with Wenol blue.
    Apparently, I need to learn how to use my new camera, as the before pics that I took, hardly show the defects at all. I have since consulted a friend of mine that told me that red is difficult to catch the flaws on and gave me some pointers in how to do so in the future. Sorry for the lack of pics, I was having issues and had some time constraints. I managed to find a couple of pics (out of the bunch that I took!) that showed them.
    I switched these to black and white to highlight the defects better.
    Corrected.
    These are pics of the side mirror. With these being black, it made it much easier to capture the defects. The whole car looked this way. I manually focused the camera on the surface of the paint to highlight the defects. When you auto focus the camera, it will focus on the light and not the actual paint surface. It will focus “through” the paint surface and on to the light. If you notice, the lights are out of focus. This is what I tried to do with the paint on the car as well, with not so great results.
    In this after photo, I kept the same focus, to make sure that I was capturing the same surface that was pictured before.
    This is the same surface with the lights more “in focus” for those that think that is a “true” assessment of the paint.
    Corrected sun shots.
    After garage pic. It was late in the day when I finished, so we couldn’t get any good outdoor photos.
    The owner was gracious enough to allow me to return and take some outdoor sun photos.
    Thanks for looking!
  2. BrendanS
    BrendanS Welcome to Detailing
    about time you posted this over here! Great detail, by far one of my favourite colours, I've got to be honest though. I've never seen a red one till now
  3. blk45
    blk45 Jedi Nuba
    Sorry x! I've been slacking. I'll do better next time. :D Thank you!
  4. yukonon22
    yukonon22 Wax on..Wax off
    nice work
  5. blk45
    blk45 Jedi Nuba
    Thanks yukon!
  6. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    I saw this three weeks ago and you have finally posted it on the forums, great job on the paint correction Eric.
  7. 911Fanatic
    Wow! Thats red. Great job on that!
  8. Denzil
    Looks fantastic Eric!
  9. P1et
    Very nice work, the red looks blinding!
  10. kogenx
    kogenx Birth of a Detailer
    That is one great looking car.! Nice work on it too@!
  11. SpecC
    SpecC Wax on..Wax off
    very nice job on a bad ass car!
  12. blk45
    blk45 Jedi Nuba
    I know......I have been slacking. Thank you for all of your help bro!
    Thanks Ken!
    Thank you sir!
    Thank you!
    Thanks!
    Much appreciated!
  13. Asphalt Rocket
    Your are welcome, I am glad the help paid off big time for you.
  14. JLs Detailing
    Wow ... just wow! Man you do some of the best work on here and I truely look forward to seeing your posts. That red just looks incredible!
  15. bryansbestwax
    lambos are my favourite. Well done
  16. slanguage
    good work :thumb:
  17. FMINUS
    FMINUS DB Pro Supporter
    dang that looks good! Never seen one in RED, and I live in SOCAL!
  18. er1k
    er1k Obsessive Detailer
    Looks good! Good work!
  19. blk45
    blk45 Jedi Nuba
    :thumb:
    I don't know what to say JL. Thank you so much. It means a lot coming from you bro! :worship2:
    Thanks!
    Thank you!
    Thanks Phil! LOL, I think you are in the Lambo capital of the world!
    Thanks erik!
  20. ampbmw
    ampbmw DB Forum Supporter
    WOW nice correction!
