Hey guys, I have an 05 Mustang GT. I really want to do a thorough detail on the engine and engine bay. The problem I have is this. The alternator is located under the intake. Its kinda hard to get to. I'm worried about getting water in it and possibly screwing something up. Has anyone ran into this problem before?? If so, how did you go about doing the engine detail? If not, what would you recommend doing? I'll post a pic later. Working now and photobucket is doing site maintenance now :fs: Thanks, Heath
Heath I've done alot of engine details where i couldn't cover up the alternator, just don't spray in that particular area with too much water and as soon as your done turn the engine on with the hood up so the water can evaporate
Thanks guys. Really appreciate the help!! What about Coil on Plug- plug wires?? Anything I should be aware of there?? Thanks for your help!!
You'll be fine, once again. Just dont get the washer right in there and you'll pretty well never have a problem on most newer cars.
I'm pretty sure you'll be alright Heath since your car is pretty brand new. If it makes you feel any better, I detailed my Integra without covering anything at all and I sprayed everything down.
Just cover the alternator with Aluminum foil and other area's of concern Heath, or just don't get does area's wet if you don't feel comfortable about them.
