1987 Mec SL300 (uk)
Discussion in 'Show and Shine' started by James B, Aug 18, 2008.
  1. James B
    James B DB Certified Manufacturer
    Ok this car came to us after a recommendation, the owner wanted some life brought back in to the paint, car was dropped to us and left for 2 weeks so plenty of time to work on it and we had a cancellation early last week so gave us even more time.
    Here is how it came to us :
    First job was to get the wheels off to clean the inner rims and arches:
    The wheel nuts where Looking tiered so i gave them a clean up with wire wool & then a coat of Silver paint (mixed to match wheel colour)
    To clean these wheels i needed some thing stronger than AS smart wheels (our usual weapon of choice) now dont get me wrong acid based cleaners are not ideal but in some situations they are the only thing that will do the job :eek: and once done right as long as you keep on top of thing hopfuly you wont need them again, so Acid based wheel cleaner (our own stuff from a local company excuse the Smart wheels tub) brushed on (dont spray acid its not good for any one) and agitated.
    Rinsed off with Hose and then repeated for the fronts:
    The tyres where sprayed and scrubbed with AS G101 and a stiff brush:
    Tardis was then used to remove and remaining tar deposits:
    Rinsed once again and clayed with Sonus Green:
    Before being sealed with Poorboys wheel sealant :
    Next job was the wheel arches, i did not want to remove all teh waxoil as this car is used and dose need the protection, but a good clean up with G101 and a soft brush:
    The next stage was to clean the engine bay, Auto Smart G101 mxed 5-1 and a long reach brush was used:
    Door shuts where treated the same:
    We now moved on to the wash stage, lowwer half treated with citrus de-greaser and agitated with soft wash brush in some areas:
    Whole car rinsed down and then foamed with Citrus snow foam and power max 3 mix:
    The soft top was scrubbed with a fabric brush, and all panel gaps and trim gaps cleaned out with a detail brush:
    Re-foamed and washed TBM with Dodo BTM wash:
    Open end hose rinsed and dried off With a WW towel :
    Panel gaps, badges & engine bay dried off with the air line:
    Rolled indoors and clayed with yellow poly clay and megs last touch as lube:
    This removed a fair bit of bonded contaminants:
    Door shuts and chrome also clayed:
    Once i was happy with the cleaning stage, we set about the first steps of paint correction, the whole car was masked off including soft top) then some paint depth readings where taken over the whole car to check for any areas that may need special care taken on or around them, this car was pretty good with any painted areas full panel jobs, so no "blow ins" :)
    The general condition of the paint was not great but having said that its 21 years old so IMO Not bad for the age, some fading on the boot was quite bad however the rest of the car was only slightly oxidised, But it was VERY! swirled :doublesho:buffer:
    So heres the line up (all exept a little FCP throwen in for a few RDS latter) :
    A sample area was taped off and i began correction work with 3M ultrafine compound and a 3M black polishing pad (this car wrecked a few pads :rolleyes:) finshed down with 3M ultrafina and megs 7 mixed in to nourish the paint and replace some oils:
    Not bad? :buffer::thumb::D
    Correction work continued around the car:
    Badges cleaned out with UFC on a Zymo! detail brush (great little trick this :thumb:)
    Paint between the the badges polished up with UFC on a Edge stick:
    Finished (but needs refining with UF)
    All these correction shots are just corrected not refined (yet ;))
    A deep RDS just under the light:
    Wet sanded with 4000:
    And polished up with 3M UFC:
    The lowers:
    The bonnet had some staining and many swirls, however 3 hits and 5Microns later it came good:
    I then went back and finished down with 3M Ultrafina on a Lcc finishing pad, while mike went around and worked on some remaining RDS (not all came out as its over 20years old its not going to be 100% but its as close as we could safely get to it :
    Door shuts where corrected:
    And then a final dusting down and masking removed:
    Paint work correction was nearly done all that was left was to prepair the paint of the LSPs, we dont usually use a pre cleanser before sealant but as the car was faded we need to put as much oils down as posible to stop the paint drying out again so Dodo Lime prime Lite was used, before we applied the first (3 in total) coat of Finish care PW, then toped with 2 coats of Dodo Super natural:
    Trim and rubber treated with CG new look trim gel:
    The roof was then dropped for us to clean all the workings and gain better accesses to the interior,
    Next job was the interior.
    The before's:
    A good vacuuming out first:
    Carpets cleaned with AS Brisc via pump sprayer:
    Fire extinguisher and holder cleaned up:
    Carpets removed and floor pan cleaned :
    Plastics and leather cleaned with UAPC
    Tool kit cleaned:
    And all chrome (interior and exterior) cleaned with Peak:
    Trim treated with 1zs:
    Wood per cleansed and waxed with Dodo:
    Interior finished:
    So we both spent 4 days on this car and in all honesty it was a great car to work on for two reasons, 1 being i really like these cars and 2 it was a great transformation IMO, see for your self:
    The finished shots :
    Thanks for taking the time to read through that lot :eek: i hope you enjoyed it and if you have any questions on the methods or products used, fire away.
    All comments and questions welcome
    James B
  2. mgreen
    mgreen Virgin Detailer
    WOW! Great work guys. Fantastic transformation on a fantastic car... :applause2:
  3. Scott's Mobile Detailing
    Scott's Mobile Detailing Welcome to Detailing
    awesome work..did one like that a few months ago...was that single stage?
  4. bigpoppa
    bigpoppa Jedi Nuba
    Holyyy shittt, pardon my french, but man that is just fantastic work. :worship2:
    BTW, it wasn't Finish Kare Pink Wax you used (I'm assuming that's what you meant by PW), but rather their sealant, #2180.
  5. ehuth1
    ehuth1 Birth of a Detailer
    Amen!
  6. yukonon22
    yukonon22 Wax on..Wax off
    Thats is stunning work
  7. Reflect
    Awesome work man, but where did you get those clear buckets?
  8. Nica
    Well done :applause: great transformation on that gorgeous classic :thumb:
  9. detaildoc
    detaildoc Guest
    Wow! Awesome job!:worship2: Love the attention to details.
  10. supercharged
    that is one awesome detail! So many pics, and results are outstanding!!!!
  11. P1et
    This is one fantastic reincarnation!
  12. littlemissGTO
    Wow the car looks brand new now. Excellent work.
  13. pirex
    pirex DB Certified Dealer
    Awsome work on a GREAT car! Love it :D
  14. richy
    Boys..what a privilege to work on a classic such as that! And did you ever do it justice! Thank you for taking the time to outline the steps involved in restoring that car to its former glory! You have a right to very proud of this one!!:applause2:
  15. James B
    Thanks for all the kind comments
    Poly wipe its called over here, sorry no it was not pink it is blue ;) pretty good product IMO
