Used my new (edit, please don't promote your detailing business unless you upgrade your account), in which the LSP is Jetseal only. Some spot polishing was asked. Car was in ok shape. Any corrections made were easy, 1 pass with white or orange pad. Notice how clean my sponge was. Virtually all the grime was gone before I got to bucket and sponge stage. Detailed descriptions per image later. I am exhausted. I wish the sun was still out...my pics would have turned out better. Ah well EDIT: I am almost positive Pinnacle XMT Pad Cleaner some dilution of CG Grimer Reaper. Wash CRSpotless for anything water--mixing, rinsing, washing, etc. Stage One - Blowing off the Dust Karcher Pressure Washer - Yellow Tip Stage Two - Degrease P21S Taw Presoak Karcher Pressure Washer - Yellow Tip Stage Three - Foam Cannon Custom Crafted in Italy Foam Cannon Snow Foam Version 2.0 Karcher Pressure Washer - White Tip Stage Four - Bucket and Sponge CG CWG Wash CG Waterspot Remover Pro-Line Grout Sponge Grit Guard CG Barebones Undercarriage Spray Stage Five - Dry Detailed Image Waffle Weave CG JetSPEED Blower Windows CG Streak-Free Window Clean Detailed Image MF Blue Clear Kote Vanilla Moose Wax Hand Glaze Duragloss Aqua Wax Clay Meguiars Blue ONR extra concentrated as lube Paint Correction Metabo Menzerna Nano Menzerna SIP 3" Backing Plate 5" Backing Plate LC White Pad Orange Pad FK 425 Detailed Image MF Blue Protection Jetseal 109 Detailed Image MF Blue Wheels Stage One -Degrease P21S Wheel Gel Presoaked for 30 minutes CG Grime Reaper for Tires Karcher Pressure Washer - Red Tip followed by Yellow Tip Stage Two - Wash Swissvax Wheel Brush CG CWG Wash Mother's Tire Scrubber Wheel Well Scrubber Karcher Pressure Washer - White Tip Stage Three - Protection ****** AIO Optimum Opti-Tire Bond Costco MF
AWESOME work mate! Thanks for taking the time to give us a proper write up! Looks fantastic. By the way, the names of your packages are funny as shizzzzzzzzzzz!!! PS: what did you use to clean your pads? And where did you get the sponge from?
THANKS! Piet I use CG Grimer Reaper because I am almost positive it is the same thing as the Pinnacle XMT Pad Cleaner. For waxes I use Dawn Power Dissolver Thanks a lot
Great work man I quick question though, did you first wash the war with WSR then rewash with CWG. I was interested in this product just trying to understand how it works. Again great work yet again :applause2:
What was the yellow stuff in the measuring cup you poured into the pad washing bucket? It's yellow? You said you cleaned the pads with grime reaper but I don't see any purple liquids in your pad washing steps? Also I take it the customer didn't want a full correction?
Thank you! Thanks!!! Grime Reaper was in the Meguiar's Degreaser bottle. It is an early/custom formula of the Grime Reaper. Customer just wanted 1 step spot polishing, which was odd cause the whole car needed it. Thanks for letting me hangout today! WASR? Thank YOU for viewing
thats how u wash a black car ..with a lot of water and soap ...u had the right products too.....i hope he gave its two coats of wax great job!!!!
Thanks for sharing that was real good detail and write up. I really like that foam gun. Maybe thats the best one I've seen.:thumb:
