help! holograms after waxing
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by xxterxx, Jun 10, 2008.
  1. xxterxx
    xxterxx Any Rag Vehicle Washer
    after i waxed my 2nd coat today , i parked my car under the sun .
    i was so shocked when i saw a whole log of swirls hologram lookalike on my car , tried using distilled water and QD , seems that i am just smudging the things around....
    what happened? whats the reason behind it?
    thanks
  2. xxterxx
    btw i used SV concorso
  3. LanceM
    LanceM DB Forum Supporter
    usually too much application or left on too long
  4. Divine Detail
    it sounds like you might just have product left on the paint and aren't getting full removal. This is just judging by how you said you move it around when you use distilled water and QD.
  5. xxterxx
    so what do i do?
    seems like oils staining my paint that hasnt dried completely
    basically my car is shiny now but under sunlight it has these 'movable' swirls
  6. xxterxx
    i called my local swissvax dealer... he told me its the cleaner fluid applied unevenly resurfacing...
    is it true?
  7. reefer_bob
    reefer_bob Obsessive Detailer
    Is it just me, or are there more and more people compaining about the SV products causing hazing and holigrams... I know I've personally seen it.
    Is there something wrong with some product, or are there just a lot of new people using it improperly?
  8. pirex
    pirex DB Certified Dealer
    Guys guys guys! Its just the wax sweating, the oils gets up to the surface when it is left in the sun. Haven`t you read the jar? It says leave it in the sun for 3-4 hours, then go over with quick finish and a mf. When you do that, you will remove the "holograms!. You can use what ever QD you have. Even dodo juice supernatural does this ;)
  9. D&D Auto Detailing
    People just arent using it correctly.
  10. Nica
    :nod: yes I agree, it's more user error than anything, I know I did that with Divine.
    Oh yes, Divine is now working well for me..lol..finaly lol.
  11. pirex
    And how are you liking divine now?
  12. xxterxx
    so whats exactly my fault? i didnt let the cleaner fluid dry throughly?
    or is it over application?
    how do i rectify it now? i looks as though i washed the car with metal brush now ...sigh
  13. pirex
    Go over the car with a QD and a microfiber towel.
    Let us know if it worked!
  14. xxterxx
    just tried...dont seem to work... tried megs QD and SV quick finish
    seems like im still smudging the finish
    will wait till tommorow i will wash the car down and reapply QD...
    encountered this before?
    is it true this is due to cleaner fluid not being let to dry completely?
    in that case did i just wasted my waxes ....sigh
  15. pirex
    Strange. ITs normal to get "holograms" after leaving a fresh layer of a high end wax in the sun. But it should be gone after QD and mf. On the bottle of cleaner fluid it says not to let dry.
  16. D&D Auto Detailing
    Apply the cleaner fluid and try again.
  17. reefer_bob
    My Smargrd did the same thing... I literally had to rip it back off and re-apply.
    Nothing I did took the wax holigrams out.
  18. xxterxx
    any idea whats the cause? because i am sure i did everything right...
  19. Denzil
    I don't know but from the sounds of it, I would start from ground zero and try again.
  20. xxterxx
    just wondering...are u suppose to rewash the car after cleaner fluid?
    or right after cleaner fluid just apply the wax...
    i did the latter... a friend of mine tell me otherwise...washing after cleaner fluid is necessary..
