tire dressing
Discussion in 'Detailing Bliss Lounge' started by bradleyheathhays, May 28, 2019.
  1. bradleyheathhays
    bradleyheathhays New Member
    What's a good long lasting tire dressing?
    I used to use this stuff called Wipe New - Tires but it's since been discontinued. There was a process. First you soaped and scrub cleaned the tire, then let dry. Then you don a 3M chemical filter cartridge mask, because no joke this stuff was noxious, then you applied just a teeny bit to the provided sponge and applied to the tire. Go around doing all 4 then then come back and do it again.
    The black lasted for a good long while...couple months before you had to do it again.
    Is there anything like this still out there on the market?
  2. Terresce
    Terresce New Member
    I like Carpro PERL and Poorboy’s Bold and Bright Gel.
    Poorboy’s gets the nod for the best “looks like a new tire” dressing. No greasy look, nice clean matte look.
  3. bigaudiofanatic
    bigaudiofanatic Any Rag Vehicle Washer
    If you're looking for matte like new tire dressing I have two options.
    Firs is my go to Dr. Beasley's tire conditioner. Clean and dry tire like normal, apply dressing and wipe down in a few minutes or wait over night for longer lasting results.
    They also make a Mattee tire conditioner but I haven't used it. (I try to keep my products to a min)
    Second is VRP from CG, again same process but don't leave it on too long.
