Rupes 21 not working
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by awdxtc, Jul 1, 2015.
  1. awdxtc
    awdxtc Birth of a Detailer
    Tonight I was in the middle of a job and my Rupes 21 stopped working. I sat it down and went to pull the extension cord over, it came unplugged for the extension cord and when I plugged it back in...nothing. I tried about 5 outlets with no success. I even waited about an hour to see if maybe it over heated. I had only been using it for maybe 40 minutes though. Any suggestions?
  2. Bunky
    Bunky DB Forum Supporter
    I would guess the power cord has an issue either in the unit or at the plug end.
  3. awdxtc
    I've contacted detailer domain and am waiting to hear from them.
  4. okay65829
    okay65829 Active Member
    Just call Phil and see what he says.
  5. awdxtc
    I tried to call but no answer. I sent dan an email which he responded to right away. He is going to pass it on to phil. The customer service they have is fantastic.
  6. awdxtc
    Unfortunately no warranty left on it. It might be time to move to a rotary machine.
  7. Chad215
    Chad215 New Member
    I work with grinders all day. If there is no warranty I would pull the handle apart and make sure a wire hasn't come disconnected . If you have compressed air blow out the brushes. Maybe the brushes need to be replaced?
  8. awdxtc
    I'm going to take it to a local repair facility. Might still get a rotary...you can never have enough tools. Overall I love the rupes.
  9. Woob
    Woob Jedi Nuba
    Maybe your bushings, tried opening it up? I've replaced my cord and found the trigger mechanism can move on replacement/positioning.
  10. awdxtc
    I took it apart last night, took the brushes out, cleaned it etc....nothing. Today I take it to a repair shop and the damn thing starts working. We will see if it behaves it self from now on lol. On a side note, does detailers domain no longer offer the uber pads in a bundle? I only see them for sale individually.
  11. Ian
    Ian Jedi Nuba
    I guarantee its the cord. Open it up, cut the cord about 12 inches back and reconnect the wires. This happened to me twice already
