Removing Polymer Net Shield
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by jackp311, Apr 14, 2014.
  1. jackp311
    jackp311 New Member
    Hi All!
    First time posting on this site.
    Before I get started, please know that I let my schedule get the best of me last weekend. I had a limited amount of time to do a few things I wanted to do on the car. (2012 Audi S4)
    I really wanted to get the car clayed and a fresh coast of Polymer Net Shield on it.
    What I skipped, regrettably, was the polishing.
    So, I had a few light scratches on there before I started. They were just built up from time, washes, and wipe downs. I think I also put a few light mars into the paint during the clay process.
    So, I can obviously hit this with my usual Rupes LHR15 w/ Rupes Yellow Pad and Sonax Perfect Finish to clear these up next time I detail the car.
    But, is there anything I need to do to strip the PNS from the car?
    I can only assume the scratches are "under" the PNS at this point.
    Thanks!
  2. detailersdomain
    you can use Sonax Multistar cleaner to remove the pns, that being said if you clay and polish it should take it right off.
  3. jackp311
    jackp311 New Member
    Well - Before I do another application, I will definitely be claying and polishing. So, if that's sufficient to remove the product, I will be fine. I wasn't sure if I needed to apply anything to get it removed before polishing to make sure I can get the scratches out.
    Thanks!
  4. MGEVOX
    MGEVOX New Member
    Nope what your planning is fine if you want use extra soap during your wash mixed with some apc but if your polishing it is going to take care of all of it either way.
  5. jackp311
    jackp311 New Member
    My go to APC has usually been simple green diluted a LOT. Is that OK for this type of task? What do people think about simple green in general? The only bad thing I know of with it is that it has butyl in it. So, using it on hot paints or wheels is a bad idea. At least, I am told so.
  6. MGEVOX
    MGEVOX New Member
    If it's working for you without adverse affects roll with it. I have been using Adam's. I'm thinking of trying Optimum Power Clean next time seems to get a lot of love. So does Meguiars D101 both are fairly economical when diluted with the Meguiars getting the upper hand in value. But the Optimum seems to be safer and I only go through about a gallon in 6 months.
  7. zerix
    zerix New Member
    I'd be weary of using Simple Green to strip a LSP. I feel it's unnecessary if you're going to be claying/polishing.
  8. jackp311
    jackp311 New Member
    Thanks Zerix - I don't know that I will be using it at all. My wash has wax like compounds in it anyway. So, the claying and polishing will be the real removal. Also, I do an IPA wipe before a new coat of PNS.
  9. GDAL
    GDAL Super Moderator
    I would try to purchase an APC that is paint safe. I have seen paint and engines get damaged by Simple Green. I rather spend a little bit more money on a paint-safe APC ... it's cheaper than a paint job. Optimum Power Clean, Sonax MultiStar, and many other are paint safe. Home Depot sells Zep Citrus and that one is safe for paint (even though it says its not). Please use common sense ... don't apply to a hot surface or let it dwell for a long time.
  10. jackp311
    jackp311 New Member
    Cool - thanks for the heads up - I am gonna place an order soon for a few items and I will check it out.
    Thanks!
