Should I put some pressure or weight on polisher????
Discussion in 'Car Detailing Product Discussion' started by punk0208, Mar 28, 2014.
  1. punk0208
    punk0208 Virgin Detailer
    Hi.
    I'm currently using rupes polisher with microfiber pads.
    some says I have to put some pressure on polisher machine, and some says just use weight of polisher?
    in my theory, I have put some extra weight , while I'm using compound. am I correct???
    plz correct If somethings wrong.
    also I guess for waxing or sealant just use correct pads with weight of the polisher right?
    thanks.
  2. kyle butler
  3. GDAL
    GDAL Super Moderator
    That article is good, but IMO, it only applies to the Griots/PC. I don't put pressure on my Rupes. The weight of the machine should be sufficient. You do need to understand that the Rupes accomplishes correction because of its stroke size. IMO, you need to control how fast/slow you make passes in order to obtain the level of cut you need. The stroke size does the work for you. Search Kevin Brown's articles here or at his site (www.buffdaddy.com) if you have a minute.
  4. The Driver
    The Driver Birth of a Detailer
    Gdal is right, sometimes going slower is and playing with the speed can yield better results. Play with the speeds before pressure.
    punk0208 likes this.
  5. punk0208
    thanks for all of reply . I'll play with speed first.
    GDAL likes this.
  6. GDAL
    Watch YouTube videos of professionals polishing with a Rupes. You will get a better idea of how fast you need to move the machine. One of the biggest mistakes I see people do is moving the Rupes like it is a rotary.
