Winter brushes
Discussion in 'Car Detailing Product Discussion' started by amz, Feb 25, 2014.
  1. amz
    amz New Member
    Maybe a n00b question...
    Got my car washed this weekend and I noticed a lot of what looks like swirlies, but in groups of straight lines. About 2 seconds later I realized this is from my snow brush clearing the snow off my car. I'm using some Costco specials with fairly soft bristles to try to keep the paint in decent-looking shape. They never touch the ground, and I run my hand through the bristles a couple of times before/after each use to "clean" them (or, rather, make sure there aren't any salt crystals lurking in the depths.) I don't push down on the brushes or force them against the car, I let the weight of the brush do all the work. The marks are concentrated around the trunk, roof, windows, hood, and mirror caps, all the areas I use the brush.
    Is this avoidable with a different brush, or just a cost of living in snow-prone areas?
  2. Meticulous-Detail
    I only use a snow brush to clean the windows, I use a leaf blower to clean snow off my cars. Don't know of any brushes that will not cause some scratches when cleaning snow.
  3. rwisejr
    rwisejr DB Forum Supporter
    Only Snow remover I use is the snow brum
  4. amz
    amz New Member
    Ice getting trapped under the broom and scratching the paint isn't a problem?
  5. rwisejr
    No never had that issue
  6. xabo
    xabo Virgin Detailer
    Next time try wrapping the bristles with a micro fiber cloth.
  7. amz
    amz New Member
    Won't that increase the risk of catching ice under the MF cloth and scraping it along the paint?
  8. xabo
    I normally remove snow down to 1/4"-1/8" and let the rest melt away.
  9. JohnsHandWash&Wax
    JohnsHandWash&Wax New Member
    rwisejr likes this.
  10. rwisejr
    Same as the snow brum it works the same but cheaper . I have one in the work truck . I like that it has a place to snap the handle for storage.
  11. JohnsHandWash&Wax
