http://www.detailersdomain.com/Uber-Yellow-Poly-Clay--240-grams--8-oz_p_164.html Description Uber Yellow Poly Clay - Fine Grade - Everyday Clay 240 gram (8 oz) The Uber Yellow Poly Clay Bars - yes these are back the ones that we all loved from a few years back. The Uber Yellow Poly Clay Bars are a fine to medium grade clay bar designed to be used for regular maintenance. The Uber Yellow Clay Bars will remove road grime, tar, tree sap, bumpy sediment, fallout, rail dust, over spray and other contaminations from your paint, glass, clear coat, gel coat, or other rough surfaces. The Uber Yellow Poly Clay Bar is a fine to medium grade which is gentle enough that it will not mark or mar your paintwork, but strong enough to remove contaminants, leaving your paintwork feeling smooth as glass. Use the Uber Yellow Poly Clay Bar and one of the detail sprays below to leave surfaces smooth and glossy ready for polishing or a coat of wax. Features & Benefits: Strong enough to remove harmful contaminants Gentle enough not mar paintwork Ideal for regularly maintained vehicles Can be used with water or your favourite quick detailer Use on paintwork, glass & metal surfaces Comes in a pack of 3 = 240 grams. Picked up a 3 pack of Uber Yellow Poly Clay last week and gave it a shot today. Very nice clay bars. I used Ultima Waterless Wash Concentrate as clay lube. Did a section of a hood on a 13 FJ Cruiser with the Nanoskin Wash Mitt and then went over the same section with Uber Yellow Poly Clay. Pkged clean clay bar Nanoskin at work Same section done with Uber Yellow Poly Clay and UWW as lube I love the Nanoskin because it saves time, but as you can see the Uber Yellow Poly Clay picked up more contaminants. Finished product Nanoskin, Clay and DG 501/601 Combo.
Duragloss 531 on any rubber and vinyl and Adams Spray Sealant on plastic trim and any matte black surfaces like the wheels and door pillars.
nice review.how long did the job take? also you had to use 2 different products to do 2 different things correct? just curious.thanks.
Took 5 hrs. The Nanoskin and Clay perform the same job, but the Nanoskin is much faster. Nanoskin works great on flat surfaces, you still need clay to remove those hard to reach areas and curves. I think clay does a better job, it just takes longer to get the job done.
