Hey there everybody, Up here is a very low mileage 2006 Cayman S in Midnight blue- the car is driven hard- autox'ed/ tracked in NASA at various tracks up here in the east coast! This Cayman is unique- I was informed that this exact model was used by Porsche for its advertising and print media, being a midnight blue/ terracotta interior combo it is a unique combination! The focus for this project was to of course revitalize the interior and remove the heavy soiling from the leather bits and various hard plastic areas but also fully correct the exterior. Correction was performed with PC/ FLEX/ RUPES D/A's, various foam pads, M101, Sonax PF Opti Coat 2.0 was used for LSP, since the car is tracked regularly, the existing clear film was left on and corrected as best possible- opti of course applied on top as well. Befores- Interior needed quite a bit of work- you can see the dark shade of the steering wheel here- tons of imbeded dirt which would be removed Soiled shift knob Door jambs Lots of dust and dirt in the rear area Front storage area needed attention Clear film was probably the heaviest defected area Wheels/ overall condition before Drivers door- magnetic number removal/ application left some serious defects and heavy RIDS as you can see below- these were addressed when correcting Defects visible in light The interior received steam/ extraction for the carpet/ mats- hard surface areas cleaned with APC- leather cleaned and conditioned Exterior- first decon wash Dawn/CG Citrus mix / Uber blue clay Sonax FE setting up nicely- sidewalls and wheel arches cleaned with APC as well Pulled in, taped up, masked off Defects before- Deeper RIDS visible in natural light Halogens worked much better to really demonstrate the level of defects..... 50/50 after first step with M101 50/50 on rear quarter Rear tails were also corrected Defects Drivers side Pillars After nearly two days and 20 hours of correcting- the Cayman was pulled outside and given a full decon wash to remove all left over oils etc- IPA wipedowns were performed but a full wash was needed to remove the excessive dust etc. Opti application Correctional after pics Pulled outside and finished up Finished interior Trim treated with Black Wow Sun Shots Thanks for looking! Dan K
Looking fantastic!! well done! Thats one heck of a unique color for an interior. Looks like a creamcicle!
Thank you! Yes, it is interesting but i LOVE it, much like the "Cork" leather P-car interiors I've worked on but much brighter...it grows on you!
