Paint Hardness Spreadsheet
Discussion in 'Detailing Bliss Lounge' started by Meticulous-Detail, Jun 13, 2013.
  1. Meticulous-Detail
    This was started on another forum and is a living growing document. It was created as a general guide for the newbie and it is in Google docs format which allows anyone to edit it and it auto saves every few seconds. I figured I would post it here so the knowledge and expertise on this forum can assist in completing this document. I did not create the spreadsheet, but did add to it. Thanx
    https://docs.google.com/spreadsheet/ccc?key=0AhSmV1SQJjifdEU5TGNRdTQ2RzNVcjQySE9QVnowWFE#gid=0
    A disclaimer was added, so you get the idea and purpose of the spreadsheet.
    *This sheet is a general guide for a point of reference and paint systems can vary from make, model and year from the same manufacturer and sometimes from panel to panel. This should not serve as replacement for a "test spot".
  2. kaiten408
    kaiten408 Jedi Nuba
    Nice, thanks for the link
  3. InsanePaint
    InsanePaint Pro Detailer
    VERY cool man. Thanks!
  4. LostHighway
    LostHighway Jedi Nuba
  5. Meticulous-Detail
    Bump. There is some serious experience on this board, lets get er done! Few more manufactures need to be filled in and add some notes.
  6. minorc
    minorc Two Bucket System Washer
    How come Subaru says "Black"?
  7. Meticulous-Detail
    Anyone can edit the document, if you see something incorrect you can fix it.
