eShine.ca - forum member promo code - news - deals
Discussion in 'Sale, Trades, or Bargains' started by eShine, Nov 13, 2007.
  1. boredstudent3
    boredstudent3 Wax on..Wax off
    can i have the discount code please?
    thank you.
  2. Celtic Bob
    Celtic Bob Two Bucket System Washer
    Chris,
    I will be placing an order soon. Could I have a code as well?
    Thanks
    b.
    Did my Dodo waxes arrive in yet?
  3. heztai
    heztai Virgin Detailer
    Chris, would you be able to provide the code to me?
  4. 378 pete
    378 pete Virgin Detailer
    Any plans for May 2013?
  5. eShine
    eShine DB Pro Supporter
    May 25th
  6. InsanePaint
    InsanePaint Pro Detailer
    Man, KILLER turnout dude, what a blast! That's great buddy!
  7. Darklol
    Darklol Any Rag Vehicle Washer
    Hi,
    I don't know if it's me or I don't see a lot of choice when it comes to washing mitts. I've been wondering what happened with the sheepskin mitts (100% Sheepskin Mitt With Thumb) they seem to have disappeared.
    Are they coming back or I should look into another mitt ?
    I'm in need of new mitts so any suggestions ?
    Thanks
  8. Pureshine
    Pureshine DB Pro Supporter
    I started using the Meg's MF mitt Ken recommended they work really well and the uber sponge is really good too.
  9. Darklol
    Thanks for your reply. I will give them a try for sure. I thought the sheepskin mitts were softer and better for washing which made them easier on making swirls but I might be wrong.
    Any thoughts on the CarPro Wool Wash Mitt ?
    Only negative point would be its one sided. I do like to flip my mitt around even tho I use on for the upper body and one for the lower body.
  10. 911Fanatic
    The Carpro Wool Mitt is the other mitt we sell. Another fantastic choice.
  11. Darklol
    Thanks for the info. Both are out of stock :( I wanted get them to try. Do you know when they will be available ?
  12. Bunky
    Bunky DB Forum Supporter
    I have a few of the meg's mf mitts and use them but they are not my favorites for some reason. It has to do with the feel but not saying they are not paint safe.
  13. ampbmw
    ampbmw DB Forum Supporter
    Preventing swirls has a lot less to do with the type of wash mitt you use, in my experience. The best thing you can do is a very thorough pre rinse with a quality pressure washer and then pre foam with the pressure washer foam cannon (better clinging better dirt removal). Also, not over exhausting your mitt when doing the washing, by this I mean not trying to wash too much at once while the mitt loses soap...if you wash a fender and then keep going onto the door without recharging / dunking your mitt with more soap then that's more friction on the door. Recharging the mitt frequently and rinsing it in your rinse bucket is important. Also, the type of LSP you have on the surface makes a huge difference. The slicker it is, the less dirt sticks and less agitation required, well you get the idea.
    I say all that (which probably everyone already knows) to say that you can use the megiuars MF mitt perfectly safely. I prefer it over sheepskin because it is more tactile on body panels, it releases soap solution better, and if well kept, they are very soft. Plus being white, they'll help indicate of you're picking up excess dirt and need to thoroughly rinse the mitt out before you keep on with it. I was looking for the best mitt to maintain with, and I have been finding this Megs mitt the perfect solution when used correctly as described above.
  14. Darklol
    Thanks AmpBMW for your post. I agree with you and I get the idea of the process on how you wash your car is more important than the mitt itself.
    I do pre rinse the car at first and then use my Riccardo foam lance to soap the whole car. Rinse it again and start with the two buckets method.
    I just though there might be some mitts finish that would create marring or swirls. To be honest, I always though microfiber would keep more the dirt than other materials.
    I still will give a try to both.
  15. Darklol
    I've sent a PM hope we can still have the coupon. I have few hundreds bucks to spend :)
  16. rwisejr
    rwisejr DB Forum Supporter
    I haven't used a mitt in a long time. All I use is the Uber sponge .
  17. bryansbestwax
    I believe Chris changed this policy. See eshine's opening page
    sent using my thumbs, mispelling most words
  18. Pmach
    Pmach Virgin Detailer
    Chris any updates for the open house this year?
  19. eShine
    We can now ship Riccardo Clay to the USA. We will also be putting a sale on it later today!
  20. mrgolfrider
    Isn't this some interesting news!
