Volkswagen Golf R Opti-Coat Detail
Discussion in 'Professional Detailer's Studio' started by Auto Concierge, Apr 26, 2013.
  1. Auto Concierge
    Recently completed Golf R in the shop that had a little "Patina".
    How it looked at the onset of the work to be completed.
    Just a tiny amount of brake dust residue.................
    Crusty film.
    RIDS.
    Sandyness.
    Time for Daniel and I to now do a 1.5 hour wash.............................
    The car is only a few months old, but the real issue was the dreaded water spot etch.
    Scuffs in the finish.
    CG gel work for the spots, repeated applications were the "Plan of the day".
    Undeniable results.
    Etching everywhere.
    Spots removed.
    Marring & etching.................. my favorite!!.
    Daniel doing the great work he always does.
    Yes more spotting.
    Removed.
  2. RZJZA80
    RZJZA80 Two Bucket System Washer
    So you DO work on "regular" cars, well now we have the proof, haha! Good work as usual
  3. slanguage
    :lol:
  4. Auto Concierge
    Some areas would require a "Light touch".
    Soft painted diffuser was etched as well.
    Making progress.
    After much effort, the vehicle came out beautiful.
    Cleaness.
    Interior De-Sanded.
    Finish corrected "Top to bottom".
    Clients soaking in the tightness...................
    Last shot.
  5. Auto Concierge
    I would roll this Golf R right now....................... what do you know "Texas boy" lol.
  6. agpatel
    Nice job bringing it back to to the condition it deserves. What is your method with GC waterspot remover? I have tried it but never really got the results; applied it with a foam app after washer and rinsed thoroughly I see your are using a mf, have you had better results that way?
  7. Auto Concierge
    The best advice for using this is you need to rub and rub till the spots soften and release by the gel or polishing them away. The microfiber towel gives the gel more bite.
  8. kyle butler
    Owner put the correct tail lights in as well. Nice car, and an amazing job as usual.
  9. Mike Murphy
    Mike Murphy Any Rag Vehicle Washer
    Nice job you two. Crazy thin paint!!! I know the feeling, I just did a Corolla that had reads in the 80's that was less than a year old.
    Also I found that the CG Water Spot Remover melted foam applicator the first time I used it.
  10. Peacemaker
    Peacemaker Two Bucket System Washer
    Beautiful work :) How many hours went into this little car? What products did you use for the compound/polish?
  11. fech
    fech Birth of a Detailer
    Great job as always! Man you two do good work. I'm the same with the water spots. I can never get them out.
  12. Auto Concierge
    I did utilize Menzerna FG400 quite a bit, as for the other stuff that will not be mentioned.
  13. Kilo6_one
    Why are you guys surprised Bob did a Golf R? He did a GTI a while back IIRC.
    Plenty of people regardless of where they fall on the payroll scale want the best, and honestly If I didnt know how to do this Id seek someone out of Bob's caliber.
    You get what you pay for in life....... literally.
    Also, most insurance companies will pay for water spot removal. falls under comprehensive with my policy............
  14. agpatel
    Spoke to a local detail and he said, "Don't care how expensive the car is, every car deserves to look good even a Pontiac Aztec."
  15. Kilo6_one
    ^^^ that is SO true.
  16. detailersdomain
    Great job Bob and Dan!
  17. Frankastic
    never fail to impress me, thanks for the tipsl, Nice save on the waterspots, as some who wetsand and buff it out.
  18. DJBAILEY
    DJBAILEY Birth of a Detailer
    Bob, are the results shown in the before & afters of the water spot etching just from rubbing the CG Water Spot Remover in with a MF, or the combo of the chemical and then compunding?
  19. waynvision
    waynvision Two Bucket System Washer
    Always love to see your work, and teamwork! Very inspiring!
  20. Auto Concierge
    The gel & compounding as there was marring in the finish as well, the trick to removing the spots is there is no trick. When they are bad the gel will need to be utilized for many applications with firm rubbing until they are removed or you can get them to release through compounding, of course you can whip out the rotary and a wool pad but then you have zipped way more material than needed and even though I want correction I also want to preserve the finish for the client in the future.
