Extension Cords for mobile usage
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by Socal Brian, Apr 6, 2013.
  1. Socal Brian
    For all you mobile detailers what length cord do you travel with? I'm trying to determine if 50ft is sufficient or 100 ft. is the better choice? Thanks in advance for all replies.
  2. bryansbestwax
    50 ft reel with 4 outlets. 2 25 ft cords.
    sent using my thumbs, mispelling most words
  3. sikedsyko
    sikedsyko DB Forum Supporter
    I bring a 50 ft that has 3 outlets on the end and then another 50ft
  4. 911Fanatic
    usually two 50' cords. Picked up a 50' 14 gauge today with a 3 plug block on the end for $38 at HD. Smokin deal.
  5. vtec92civic
    vtec92civic Nuba Guru
    100ft is normally sufficient bit as stated above I'm various lengths. I jave 2 100ft cords right now but looking to retire one of them and get a 50 ft-er
  6. 604_Snooze
    604_Snooze Obsessive Detailer
    Do you guys get the 12 or 14 gauge extension cord?
  7. LostHighway
    LostHighway Jedi Nuba
    Unless you're certain you'll only be using low current draw devices if you're going the run a 100' extension cord or daisy chain two 50s you'd be smart to opt for 12 gauge.
