Is the MTM Hydro Lance 1/4 threaded and 1/4 male piece? I know the male piece is a 1/4 but I am seeing if the threaded side is a 1/4, any help is appreciated.
does that help? in the first pic, don't look at the contents of the bag, i use it for storage. but the bag is for the proper connector shown in the second pic. the connector is threaded on both ends, and connected as shown. 1 end goes into the pressure washer adapter, and the other end goes into the lance head.
I am talking about the piece my finger is pointing too (threaded side) lol. For some reason that male 1/4 is too long so I am getting one that matches the tips that came with the PW.
So since its declared a 1/4 inch can I find the male side tip that fits the same size as the piece from the power washer.
i have that same piece also, it's stored in the bag in the first pic. it comes with the MTM by default and i took it off b/c i couldn't connect the PW to it. i needed to buy the 1/4" hex nipple so that the PW adapter (black plastic piece in second pic) could fit on the other end when i assemble it together, the threads do not go all the way in. there is some sticking out like the same in your pics, you can see the threaded portion with the teflon tape it's "niple hexagonal" for you, quebec'er...lol...:
See, I was hoping I could find a similar quick connect male piece like the one in the photo showing one of the Tips that came with the PW then thread it into the back of the MTM Hydro like it is now.
