Pressure washer / Foam lance combo Q's?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by SRT8Spartan, Feb 16, 2012.
  1. Pureshine
    Pureshine DB Pro Supporter
    I have the clean force and no you don't.
  2. JoeyV
    JoeyV Welcome to Detailing
    Well, you need the quick release fitting.
  3. Chrismonson
    Chrismonson Virgin Detailer
    Which is already on the cleanforce right?
  4. JoeyV
    The actual quick release is on the clean-force, but you still need the fitting that goes into the foam cannon so it mates to the clean-force. It kind of looks like a fitting one would use for an air compressor attachment. You can find it at home depot for 2$
  5. golfer1659
    golfer1659 Virgin Detailer
    Does anyone have a link to this part??
  6. flash69
    flash69 Virgin Detailer
    I have both the MTM foam cannon and the Clean-force PW. The MTM FC I received came with the quick connect connector and a screw on connector, however the quick connect connector would not fit on my quick connect on the PW lance. After looking at the PW and FC I found that you can unscrew the PW lance extension and screw on the other included MTM connector. I use my MTM FC this way because it seems more balanced compared to how long it would be with the PW gun, lance extension and then the FC.
    So for me screwing the FC onto the PW gun is a better solution although I lose the quick connect and disconnect feature.
  7. golfer1659
    You might have a older model then me because my other piece that came with the MTM does not fit after you take off the lance extension........still waiting to hear from Joey V
  8. flash69
  9. golfer1659
  10. golfer1659
  11. Chrismonson
    Mine hooked up right to it didn't need any type of adapter...
