Nissan GTR Full Correction- Premier Shine
Discussion in 'Show and Shine' started by premshine09, Aug 10, 2012.
  1. premshine09
    premshine09 Jedi Nuba
    Hey all,
    Spent close to 20 hours on this one over a two day period performing a full correction on my clients GTR. The car had some trouble areas where scuffs and marring were present- the car is driven several times a week and he has taken it on many trips including the recent GTR experience at Monticello close by here in NY.
    Corrective materials and tools:
    Flex DA
    PC DA
    Surbuf R- M105
    Yellow foam- M105
    Green foam- Sonax Perfect Finish- Thanks Todd C!
    LSP- two coats of CG JetSeal 109- durability was important to client as the car is driven very regularly!
    Onto the befores:
    Heavy soil and dull finish noticeable right away
    Defects under natural light
    One of two scuffs found on body
    Many bugs on the front end
    Wheels were caked with heavy break dust- as were the brembo calipers
    Massive exhaust tips were in much need of some help!
    Lets get started
    Motor before:
    Thats funny.
    The motor was gently brushed down with an SV brush, ONR / Megs APC and dressed carefully with 303 AEP
    Thorough decon washed performed- Megs APC to pre-treat/ clean wells
    - wash was performed with lambs wool mitts and CG citrus wash and clear/ Dawn mix to strip off old LSP
    Sonax here breaking own the heavy dust
    The car was dried and pulled into garage for a thorough clay with an Uber fine grade bar
    Masked up and under the lights before correection
    50/50's after two passes with M105 Surbuf R then Yellow
    Full after compounding
    More 50/50's
    Passenger side door defects
    Rear area showed the heaviest damage- very easy area to correct and LARGE
    Befores:
    50/50 and afters
    Under natural dim light- NOTICE the difference between left and right
    DAY TWO:
    After a thorough IPA wipedown it was time to finish down. Due to the softness of the GTR's paint, which is comparable to the Brilliant Black paint found on the GT2 RS that I take care of (much like BMW JB) I knew I was going to need a proper finishing polish that would not only be aggresive enough to remove the compounding haze left from M105/ Yellow foam and still be finish down properly without leaving very fine-line micro swirls. Out of all my correction materials (mostly the Menzerna line) I have not found a perfect finishing polish that finishes down 100% PERFECTLY and works well to my taste.....well, not until now.
    After seeing a blog post by Todd C. of Esoteric featuring Sonax new Perfect Finish polish and how stellar it performed as a one-stepper while finishing down perfectly on soft dark paints (what is was designed for) I had to give it a try. The week before I had been up to my clients estate to perform basic mantenance washes on his collection, I took 15 to try it out on the GT2 RS and I was ecstatic as to how it performed!
    I spent close to 5 hours going around the GTR with Perfect vinish via a Green foam pad and loved every second of it. Dusting was VERY minimal to nothing, quickly finished down around speeds 4.5 to 5 on the Flex and kept the surface very cool- wipe down was a breeze.
    Before LSP app
    Time for the finer points and wrap-up
    Now that the main parts of the body were finished down and LSP ready I turned to the smaller areas-
    In order of completion
    - 2 stepped the A-pillars
    - Corrected out the headlight lenses with Sonax Perfect Finish on an orange pad via PC
    - Polishd the wheel faces (1 hr) via PC
    Wheel faces before
    Afters:
    Random Afters
    First coat of Sealant curing here
    Meanwhile I took to finishing up the big Brembo calipers with several Q-tips (the long ones Docs use) soaked in APC to hit the tighters areas I missed with my SV brush.
    The interior was vacuumed out, blown out with compressed air and wiped/brushed down with a boars hair brush and APC- glass cleaned in and out.
    The exhaust tips had been de-ironized with Carpros ironx gel, hit with #0000 steel wool, hand polished with P21s polishing soap and then handpolished again with Megs all metal polish to bring them to perfection.
    2 coats also going on the wheels of course as well
    _____Afters______
    Motor after
  2. Chas
    Chas DB Forum Supporter
    Absolutely awesome work, that thing is pure mint now. Great job dialing that in man.
  3. ampbmw
    ampbmw DB Forum Supporter
    Wow, I'm actually really really impressed on that one. Your correction work looked mint man, looks like it turned out perfect.
    Very impressed!
  4. ampbmw
    That dragon in the background is a little creepy though...
  5. premshine09
    Thanks! I was excited to see the outcome- adding a GTR in my portfolio was a great opportunity! I really enjoyed working with this paint, never had too much trouble with it as I have had with BMW JB and others....
    The dragon is HUGE in real life and caught me by surprise but I think its cool and DEFINITELY fitting for the car the owner has!
    - Dan
  6. React
    React Birth of a Detailer
    I've had my eye on the Sonax perfect finish as well after reading Todd's blog... Great writeup and work!
  7. premshine09
    GET IT. I have an F430 booked for monday for a one-stepper and I'm gonna see how the Perfect Finish works on the PPG Rosso
  8. boredstudent3
    boredstudent3 Wax on..Wax off
    great job Dan!
  9. Pureshine
    Pureshine DB Pro Supporter
    Car came out amazing!
  10. Todd Cooperider
    Todd Cooperider Virgin Detailer
    Congratulations on such stellar work...the car came out amazing! Being able to finish down perfectly (particularly on dark, soft paints) under all lighting conditions really separates a good detail from a great one for sure, and glad you found the solution.
  11. React
    Enjoy your work..welcome to DB!
  12. boredstudent3
    welcome to DB, glad you're on this forum.
  13. premshine09
    X3!! Thanks for the comment Todd!!
    - Dan
  14. TimAD
    TimAD Jedi Nuba
    Impressive work on the Unicorn (Black GTR paint) of paint correction!
