Spray Bottles
Discussion in 'Car Detailing Product Discussion' started by K3RMiTdot, May 1, 2012.
  1. K3RMiTdot
    K3RMiTdot DB Forum Supporter
    Looking to get a couple spray bottles, not sure how many to get...
    Possibly wanting to get a couple from HD,
    How many people have the kwazar ones and love it?
    I dont know if its worth the price tag, although though i would love to get a foam one
  2. cu2mike
    cu2mike DB Forum Supporter
    Get the spray master bottles from HD.
  3. mrgolfrider
  4. dr.jay
    dr.jay Birth of a Detailer
    US plastics wide mouth sprayers make life easy when making dilutions, no need for a funnel
  5. LostHighway
    LostHighway Jedi Nuba
    I'm in the have Kwazar bottles and love them category. Aside from the double pump, the spray is more adjustable than the Spraymaster bottles and the Kwazars are more stable when you set them down. I haven't tried to use them with anything extremely acidic, base or solvent-y (really, why would you?) but I have stored them with OPC at 3:1, CG Diablo at 3:1, 20% IPA, etc. in them and they have been fine. The big Venus Pro compression sprayers also seem great but I haven't used them long enough to determine ultimate durability. IME big box store .5l - 2l compression sprayers are craptastic.
  6. 911Fanatic
    I have the Kwazars and wouldn't buy again. Basically its a $13 trigger on a $1 bottle. The Griots Finest Sprayer ($3) moves a ton of liquid and its very adjustable. If you have to do a lot of spraying, things like APC etc, then the 1L pump sprayers are the ticket.
  7. cleung
    cleung Any Rag Vehicle Washer
    I like the ZEP spray bottles from HD
  8. Rennes
    Rennes Jedi Nuba
    +1 for that. Home Depot's spray bottles are so cheap and very reliable :)
  9. Wheelz25
    Wheelz25 Jedi Nuba
    I have a 2 kwazars for wheel cleaner and clay lube and then a ton of the wide mouth ones from usplastics for all my other products...apc, window, tire shine, 303 protectant, and all my other specific cleaners.
  10. Kilo6_one
    Grey top sprayers from USPlastics is all I use, and they take wheel brightner like a champ which is one of the most caustic products you can run through a sprayer, it atomizes the products to a very very fine mist.
    bottles also have dilutions ratios printed on the bottle so that is a plus as well.
  11. K3RMiTdot
    i dont want to get from usplastics, im in canada, shipping is going to be a pain in the ass!
    Link for the grey top sprayer? i searched no luck? ,maybe under another name?
  12. cu2mike
    They're Viton sprayers.
  13. K3RMiTdot
    i see the sprayer not the bottles:S
  14. cu2mike
    That's the grey sprayer he was talking about.
  15. GloomyX
    GloomyX Birth of a Detailer
  16. Upper Class Detailing
    Meg's chemical resistant sprayer for me + Meg's bottles.
    HD ones are not so good for chemicals.....trigger gets stuck, then you need to apply some WD-40 and then repeat the process. I believe same applies to Kwazar sprayers.
  17. v|nsan|ty
    v|nsan|ty Obsessive Detailer
    ^ The RL-Flo Master is great for something like clay lube. It makes covering the entire panel effortless as you don't have to go wild pressing a regular spray trigger.
    From my experience, the Zep spray bottles don't foam for me. I bought a Griot's foaming sprayer head just for kicks and those actually work quite well. It uses way more product but does a great job of foaming. Otherwise, my go to spray bottles are Werkstat ones. The spray head is the same as the ones given by Chemical Guys and the bottle is a nice size, coming in at 16oz.
  18. GloomyX
    Where did you get your Werkstat bottle?
  19. v|nsan|ty
    Ken hooked me up with them :thumb:
  20. GloomyX
    Oooo.... must inquire!
