Removing Wax/Oils for Wolf's Body Wrap prep
Discussion in 'Car Detailing Product Discussion' started by R-Q5, Apr 10, 2012.
  1. R-Q5
    R-Q5 Virgin Detailer
  2. Chaseme
    Chaseme DB Forum Supporter
    You are correct; many people do wipe downs (one or two times) with IPA to ensure proper adhesion. It is recommended to dilute IPA down from the 99% or 70% to something closer to single digits; it has been brought to attention that higher concentrations can dry out the clear.
    There are also some ready-to-use sprays on the market like Menzerna Top Inspection.
    Otherwise, other techniques include washing the vehicle again with a non-gloss enhancing/silicone containing soap.
    But at the end of the day, this step ensures longer life of the product; which in the case of BW it's said to be around 6 months. Even if it lasted 3 months that would be a huge length of time.
  3. R-Q5
    i just remembered seeing something in a post about carpro eraser. Would that work if I didn't want to go through the dilution process?
  4. Darkstar752
    Darkstar752 Horizon Detailing
    Yes, Eraser would work fine.
  5. onebaucom
    onebaucom Birth of a Detailer
  6. R-Q5
  7. dsms
    dsms DB Forum Supporter
    Don't over complicate things, do a few strong IPA wipedowns and your good to go.
  8. detailersdomain
    IPA wipe down or Shine and Seal will do the trick.
  9. R-Q5
    Thanks for the tips guys.
  10. porta
    porta Jedi Nuba
    You can also give it a wash with a alkalie to remove the polishing residues and oils. But remember to dry the car very carefuly after; paint sealants and - especially - coatings don't
    like water.
