Iron cut
Discussion in 'Car Detailing Product Discussion' started by JSF721, Sep 24, 2011.
  1. JSF721
    JSF721 Jedi Nuba
    Do you apply to a washed car while it is wet? Recently did my car and there was very little reaction. I applied it to a washed car bit left the surface wet from rinsing. Is this proper procedure?
  2. apadilha-pe
    apadilha-pe Virgin Detailer
    Try use it in a clean and a dried car or rim.
  3. chemgys99
    chemgys99 DB Forum Supporter
    dry or wet works.ur car might not have a lot of brakedust/raildust on it.make sure you let it soak in for a while.
  4. luke093
    luke093 Welcome to Detailing
    Dried works better as there is no liquid to dilute the chemical itself.
  5. apadilha-pe
  6. Phil.P
    Phil.P Any Rag Vehicle Washer
    This!
    Make sure to cover all the car with it. Also, use a mask and gloves!
  7. TechnikSLR
    TechnikSLR Two Bucket System Washer
    x2
    this stuff smells brutal
