All Purpose Cleaner Recomendations?
Discussion in 'Car Detailing Product Discussion' started by mx22, Jun 28, 2010.
  1. merlin3008
    merlin3008 Birth of a Detailer
    +1 for the Zep product line. citrus 3:1 is great for most jobs. purple degreaser for tires.
  2. TheRustySuper
    I use Meg's APC...it works good and it's not too expensive. When you primarily detail minivans you don't want to be paying a ton for something you'll go through relatively quickly. I've also used MS Super Green Stuff and liked it, but had trouble finding it.
  3. Upper Class Detailing
    +1....4:1 for rims and tires
  4. Emile
    Emile Welcome to Detailing
    I just want to say that APC+ does foam up but the foam goes away aftter several seconds.
  5. Streetlife
    Streetlife Birth of a Detailer
    Poorboys biodegradable APC, and CG GreenClean APC.
  6. Frankastic
    no Chemical guys grime reaper here?
  7. pektel
    pektel DB Forum Supporter
    I use grime reaper, but only on exteriors.
  8. ziggo99
    ziggo99 Birth of a Detailer
    Vote for Meg's APC+. Love that stuff. Although the fumes can get to you, so a mask might be a good idea to wear.
  9. cnut
    cnut Guest
    Zep citrus
    DG apc
    Meg's green apc, all of these I've used with good results diluted 3:1 or 4:1 on the exterior.
  10. slanguage
    grime reaper on exteriors and 1Z blitz for engines and some interior things.
  11. GDAL
    GDAL Guest
    zep citrus and power clean. There are two things I don't like about power clean ... it really dries your hands and seems to dry up on the paint faster than zep citrus. It's stronger than Zep though.
  12. bonehead
    bonehead Jedi Nuba
    Any problem of using Zep citrus undiluted on engines or paint?
  13. bryansbestwax
    PG 99 baby, but it isnt' available to you. Megs APC + or even Kleenol are great.
  14. ltebow34
    ltebow34 Birth of a Detailer
    I dont like Zep, I use it for pad cleaner now, it was too hard to rinse off paint. I like OPC rinse very well and safe on paint, wheels(for washing with ONR)
  15. JC98
    JC98 Birth of a Detailer
    +1 for Zep citrus at $9 a gallon you can't beat the price.
  16. Sergeant Fancypant
    Sergeant Fancypant Virgin Detailer
    Hey guys i need a good APC. Any idea where can i buy locally here in Canada? Preferablly Meguiars APC or Zep as many people suggested.
    What dilution should i use for door jams and wheel wells?
  17. apadilha-pe
    apadilha-pe Virgin Detailer
    Zep is the bomb hand cleaner?
  18. Phil.P
    Phil.P Any Rag Vehicle Washer
    You can buy the whole Zep line at Home Depot in the cleaning section.
    What you should consider from Zep is : Citrus, Cleaner & Degreaser (purple), APC and Premium Carpet cleaner.
    To clean up door jams and stuff, APC or Citrus @ 3:1 / 4:1 should do the trick.
  19. xjapanx
    xjapanx Any Rag Vehicle Washer
    I use Chemical Guys Grime Reaper on light duty exterior and 1z Blitz for tougher stuff like engines and wheel wells.
  20. Chaseme
    Chaseme DB Forum Supporter
    Really? I have both but feel Grime Reaper to be stronger.
