Rubber door trim:
Discussion in 'Interior Car Care' started by Dannyk, Sep 22, 2011.
  1. Dannyk
    Dannyk Jedi Nuba
    I have a client who is pretty anal when it comes to rubber door trim, i currently use Gummi Pflege. Any favorites that you use or recommend ?
  2. Kilo6_one
    Ive used Hyper dressing and CG VRT applied with a small foam block.........
  3. Phil.P
    Phil.P Any Rag Vehicle Washer
    I use Poorboys Trim Restorer. I find that if you dont let it soak up, it will put smudges on stuff.
  4. Legacy99
    Legacy99 Wax on..Wax off
    I don't think you'll find anything better.
  5. Mr. Gloss
    Mr. Gloss Virgin Detailer
    SilGlyde is a good choice, but it must be wiped dry or it attracts dust.
    NuVinyl (yes, on rubber) is also a good choice. Don't judge it until you've tried it.
  6. Chaseme
    Chaseme DB Forum Supporter
  7. Bmer89
    Bmer89 DB Forum Supporter
    Gummi is great stuff, I also use CG VRP. There is a product Honda makes that apparently is amazing at keeping up seals. I've yet to try it, but I want to. I'll look it up again.
    EDIT: It's called Shin Etsu, Honda part #08798-9013
  8. tfish1
    tfish1 Birth of a Detailer
    i think i kno what your talking about ill get back to you with results
  9. Bmer89
    Awesomesauce. I edited my post, is that the stuff? I'd love to see how well it works!
  10. Stokdgs
    Stokdgs Detail Master
    I've had great success with Einszett Gummi Pflege Stift (Rubber Care Stick) and Einszett Vinyl-Rubber Care and Protectant Tiefenpfleger - This is a 500ml bottle with a sprayer.
    The original BMW Gummi Pflege in a tube was the most perfect product, except they quit making it.
    Dan F
  11. tfish1
    i used the honda stuff at work it was good but what i also tried was the wurth rubber and vinyl care in an aresol can and i was definitely pleased with the results
  12. xjapanx
    xjapanx Any Rag Vehicle Washer
    Another vote for Gummi Pflege, the product is really good if you can get the product to come out consistently due to the gravity pour.
  13. Believe
    Believe Any Rag Vehicle Washer
    Another vote for Einszett Gummi Pflege. I love this product !!!
  14. P1et
    1Z Gummi Plfege is great, but so is 303...
  15. Upper Class Detailing
    Duragloss Marine & R/V Protectant #531 seems to be a great product.
  16. Meticulous-Detail
    I use DG 531 for rubber trim.
  17. HeavyD
    HeavyD DB Forum Supporter
    Agree completely! Damn VOC regs. I have the 1Z Proline Vinyl Gel coming my way soon,have you used this Dan?
    Darren
  18. Stokdgs
    Hi Darren, sorry for the late reply :(
    No, I have not tried the 1Z Pro Line Vinyl Gel - sounds like a great product, like all their others though..
    Thanks for the tip - I will go see about getting in line for this too !
    Dan F
