CG Maxi Suds II Question
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by UR2SLO, Sep 17, 2011.
  1. UR2SLO
    UR2SLO Any Rag Vehicle Washer
    Hey,
    What are most of you guys who have Maxi Suds II using as a ratio in a foam cannon? I use about 30ml of it with 900ml waster (1 liter bottle) and find that it doesn't sud much.
    Thanx
  2. richguy66
    richguy66 DB Forum Supporter
    I haven't used MSII but 30ml sounds very little. I usually dilute 1:9 for foam canons (depending on soaps of course).
  3. UR2SLO
    What does 1:9 translate too haha? How many ml of soap and how many ml of water?
  4. Kilo6_one
    1 oz.....per 32 Oz is what I use and it works fine.
  5. jkarte
    jkarte Virgin Detailer
    100ml soap, 900ml water :)
  6. supercharged
    I usually use 2 oz of soap per 16 oz of water. Works well...
  7. M3ride.
    M3ride. Wax on..Wax off
    Same.
  8. Danny
    Danny Nuba Guru
    2 oz per 900 to 1000ml of distilled water in my foam cannon
  9. Chaseme
    Chaseme DB Forum Supporter
    Yeah. I don't measure carefully but it's probably 1:20 and it works well. Helps to gently shake the gun to get suds built up (read: no pressure washer).
  10. jjl
    jjl Birth of a Detailer
    I use about 2 oz also. Might give 1 oz a try per kilo's suggestion. There does not seem to be a lot of room with the dial settings on my lance, pretty much one setting hits the spot for foam but also not using up too much soap.
  11. Kilo6_one
    I think 1 oz is enough since its a very high foaming product, and in combination i a foam cannon (not a foam gun) it foams up enough and very nicely. Now with a foam gun attached directly to the hose I would increase the amount. The foam cannons have more pressure and can produce more foam versus a foam gun.
  12. boredstudent3
    boredstudent3 Wax on..Wax off
    1 oz i think is 30mL
    ^ this. i use 2 oz in the foam cannon bottle as well. suds nicely. not shaving cream though.
  13. UR2SLO
    Tried 2 oz today didnt getting the "shaving cream" look. Do I need like 4oz for that haha?
  14. TimAD
    TimAD Jedi Nuba
    Dont be afraid to put a little more soap then less soap in a foam cannon. Usually anywhere from 2-3oz does it for me.
  15. dr.jay
    dr.jay Birth of a Detailer
    I used 6oz in my foam cannon but I think something is up with my Karcher PW, it still doesn't give outstanding shaving cream like foam. I also have MS Super Foam that I have yet to try, I'd like to compare both when I pick up a new PW
