Detailer's Domain: 2008 Audi A6 - Detail
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Aug 8, 2011.
  1. detailersdomain
    Customer wanted a thorough job with intent to trade the car in for a new Audi A8.
    What was done -
    Exterior
    - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes
    - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down
    - Wheel wells were cleaned up
    - Pre Washed with W99
    - Iron Cut
    - Wash down and rinsed
    - Door jambs were cleaned up
    - Clayed
    - Dried
    - Tires dressed
    - Masking
    - Paint Measurement
    -1 Step - Menzerna Power Finish
    - Inspection with Fenix, 3m Sun Gun, Infratech, and natural sunlight
    - Last Step – 1Z einszett Glanz Wax
    - Wheels and tires cleaned
    - Rubber and Plastics Treated
    - Exterior windows and mirrors cleaned and sealed
    - Exhaust tips cleaned
    - Windows were clayed, cleaned, and sealed
    - Jambs steam cleaned
    Links to products used -
    1Z einszett W99
    Iron Cut
    Adam's All Purpose Cleaner
    Sonax Full Effect Wheel Cleaner
    Adam's Undercarriage Spray
    Uber Clay Bar Kit
    Optimum Opti Coat 2
    Adam's Super VRT
    Adam's Metal Polish
    Adam's Glass Cleaner
    Interior
    1Z einszett Cockpit
    1Z einszett Leathercare
    Tools used
    Uber Wool Wash Mitt
    Uber No Name MF Towels
    Flex PE14-2-150
    Uber Buffing Pads
    Defelsko Paint Meter
    Fenix TK35
    Brinkmann
    Kranzle Pressure Washer
    Cam Spray Foam Canon
    2 Grit Guard Buckets with Caddies
    Uber Firehose Nozzle
    Metro Air Force Blaster
    Before interior
    After interior
    Before shots of the car
    Pre wash/Iron Cut/ Rinse /Wheels/ Engine Clean Up/ Clay
    Before shot of wheels
    Before shots of the engine
    Adam's All Purpose Cleaner working its magic
    Adam's In and Out used to dress the engine
    Courtesy windshield washer top off with 1Z einszett Kristal Klar
    After shots
    Rinse
    Iron Cut applied then rinsed
    We used W99 to wash the car
    As you can see clay was still needed
    Close up
    After polish shots
    Cleaning up the jambs / vac and 1Z einszett Spray Wax
    Removing inspection sticker residue per customer
    Final wipe down and inspection
    After shots (einszett Glanz enhancing the metallic flakes)
    Enjoy!
  2. yyaman
    yyaman Two Bucket System Washer
    Phil,
    You really know how to make me depressed! I use the same products you use (except that I use a PC instead of Flex) and the results I get are no where near yours.
  3. detailersdomain
    should be the same if not better ; )
  4. Kilo6_one
    What kind of spray head is on the Adams APC?
  5. detailersdomain
    special issue black Kwazar ; )....
    we put Kwazar triggers on just about 99% of all our bottles.
  6. pektel
    pektel DB Forum Supporter
    Looks like some hella bad mineral streaking on that back glass? I'm guessing glass was done after that pic...
    Turnout looks great, as always :thumb:
  7. detailersdomain
    I can assure you we did not delivery the car with dirty glass.
  8. pektel
    I was just giving you a hard time, Phil :thumb: :D
  9. detailersdomain
    yes I figured however I had to make sure others will know we did not deliver the car that way.
  10. M3ride.
    M3ride. Wax on..Wax off
    Awesome work Phil!
  11. detailersdomain
  12. paixim
    paixim Virgin Detailer
    hi Phil, do you mind sharing how you clean the sticker residue from the glass? thanks
  13. P1et
    Looks damn fine Phil, still love the way these Audis look. S-Line doesn't hurt!
  14. froboy272
    froboy272 Obsessive Detailer
    window cleaner and a razor blade.
    Nice job on the car phil! Paint looks awesome.
  15. froboy272
  16. detailersdomain
    correct razor blade and glass cleaner
  17. paixim
    Thanks guys. I have one more question - Doesn't razor blade scratch glasses? Do I just use the dull edge to "push" and lift the glue?
  18. rwisejr
    rwisejr DB Forum Supporter
    Hey you should put then up in the store . I know I would buy some !!!!!
  19. detailersdomain
    the kwazar bottles are already up for sale.
  20. WashingJosh
    WashingJosh Jedi Nuba
    paixim, if you use a razor blade make sure it's stainless steel and new. Obviously plastic wont scratch but carbon blades will.
