Chemical Guys polishes????
Discussion in 'Car Detailing Product Discussion' started by awdxtc, May 22, 2011.
  1. awdxtc
    awdxtc Birth of a Detailer
    Just curious if anyone here had used the chemical guys paint correction polishes and how you liked them.
  2. Danny
    Danny Nuba Guru
    No but I would defiantly like to give them a try after seeing Marc Elsworth do this with them
    [video=youtube;0zTx36ZBTwY]http://www.youtube.com/watch?v=0zTx36ZBTwY[/video]
  3. Frankastic
    Marc is the only one I kno who uses it. you may or may not get the same results. I will stick to Menz, Megs, and Opt for now.
  4. awdxtc
    I wish I could uses a rotary buffer.
  5. Frankastic
    Its not as hard as many may think it is. just start with a light polish and 5.5 blue uber pad at 1200 rpm or lower for practice. keep the buffer moving at 1 sec per 2 in ( depending on paint ) with no pressure on horizontal surface. once you get a hang of it, do the same on vertical panels with some pressure to keep the pad on the surface or else it'll jerk, throwing you around.
  6. awdxtc
    ok whats like the max speed you would ever need to use? There should be an instructional thread for this.
  7. sal329
    sal329 Nuba Guru
    I wanna try there P40 I think is what its called its the one step they have.
  8. Frankastic
    theres no instructions, every car is different. I seen speeds up to 2100 rpm from pros on some hard clear coats. 1200 rpm- 1500 rpm seems like what most use to correct paint.
  9. Upper Class Detailing
    For instructions you can check this thread out
  10. infinity
    infinity Any Rag Vehicle Washer
    Every product that i have that CG produce has been a joy to use and nothing but fantastic finishes if used correctly.
