Hows this pressure washer for a weekend warrior?
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by stingray23, Mar 31, 2011.
  1. stingray23
    stingray23 Jedi Nuba
    I just looked at the lavor fitting too.
  2. co78
    co78 DB Forum Supporter
    just got the foam cannon today, the lavor fitting is a bit too long.
  3. stingray23
  4. philttz
    philttz Any Rag Vehicle Washer
    I have a camspray 1500a for sale, pm for details.
  5. Rennes
    Rennes Jedi Nuba
    Since I got to use a gas powered one, I'll never go back to electric PW. I've went thru 3 PW so far, a cheap home depot one, a snap-on and a simoniz.
    I've got a Karsher gas powered from costco, 2600PSI 2.3gal and it's perfect. It's not that loud actually and does a very good job with the proper white nozzle. Shooting foam with this is unbelievable.
  6. kakeuter
    kakeuter DB Forum Supporter
    Glad you found a stable unit that works well for you. Everyone has their preferences, I liked using our gas-powered pressure washer, but I hated lugging it around (we're mobile) and I always ended up turning it on/off when I was using it since it was loud. It went through gas way too fast too, but it wasn't that new of a unit.
    I agree that you should just spend the money up front and buy a reliable unit, the AR610 was $489 and I have zero regrets because the unit is awesome!
    -Kody-
  7. stingray23
    can I return mine through Amazon if I dont like it? I've only used it once.
  8. jsraaf
    jsraaf Any Rag Vehicle Washer
    I'm pretty sure you could. I returned mine, though it was defective (and the issue of not being compatible w/the foam cannon I bought). You have to choose one of the reasons for the return when you get the return label. You may not get your original shipping refunded however.
  9. stingray23
  10. 05A4USP
    05A4USP Virgin Detailer
    I bought the AR 383 back in December. It works well but I haven't found a fitting to use the Cam Spray Foam Cannon. The AR definately uses and odd fitting. I tried a universal kit from Home Depot and none worked. I think the only remedy is to replace the hose and trigger/wand to one that utilizes a quik connect setup. That is going to cost probably another $100. I should have spent $100 more on the actual pw and got one ready to run w/o having to make changes to it.
  11. Danny
    Danny Nuba Guru
    Check out the fittings below the foam lance and see if one of those is it.
    PWMall-FL803-Adjustable High Pressure Foam Lance w/ 32oz Bottle, Sprays Up To 20
  12. stingray23
    Thats what I thought. I wish I would've done more research before I purchased it but I had a specific budget and definitely didnt want to spend $1000.
  13. stingray23
  14. Danny
    Danny Nuba Guru
    Take a picture of the fittings that are on your AR lances and post it then we can see which one it could be or you could give them a call which ever you prefer
  15. 05A4USP
    the Home depot kit came w/ a Lavor, Bosch and a Kew/Alto fitting. Neither one fit. The AR nipple is narrow compared to the others. The only possible fit would be the Bosch if you grind down the shoulders/tabs so it can go further into the wand.
  16. stingray23
    What was AR thinking when they designed that useless fitting?
  17. Danny
    Danny Nuba Guru
  18. jsraaf
    None of the adapters from that PowerCare adapter set from HD will fit the AR383 - believe me, I tried.
    That's why I returned the AR383 and got a Karcher, for which adapters - and cannons, etc. that will work with them - are readily available.
  19. jsraaf
  20. Danny
    Danny Nuba Guru
    Its not the same man that is a 64 oz foam lance the one I have is a Mecline foam lance and its a 1000ml which is a 33.8 oz foam lance. I wouldn't want to be using a foam container that large its not necessary to use that much of a water/soap mixture to snowfoam a vehicle.
