Bmw 1 m!
Discussion in 'Detailing Bliss Lounge' started by detailersdomain, Dec 13, 2010.
  1. detailersdomain
  2. detailersdomain
  3. kyoshiro
    kyoshiro DB Forum Supporter
    i dont fit in a 1 series, im too big lol
  4. detailersdomain
  5. detailersdomain
    BODY/SUSPENSION:
    * High strength steel unibody with widened fenders and track
    * Metal roof panel (saves 35lbs over 1-series with moonroof)
    * Aluminum suspension from E90/E92 M3. Virtually all of the front-end components are aluminum; virtually every detail on the five-arm rear axle is made of aluminum
    * Weight balance of 51.7% front 48.3% rear
    * Weighs in at 1,495kg DIN (3,296 lbs, preliminary)
    BRAKES/WHEELS:
    * Brakes from M3 featuring internally-vented, cross drilled cast icon discs – 14.2 inch front, 13.8 inch rear. Each disc is connected to a floating aluminum hub by cast-in stainless-steel pins which reduces the thermal loads on the discs, thus increasing their performance and service life.
    * Dash display brake wear indicator monitors condition of the brake linings.
    * M3 Competition / M3 GTS competition wheels – 19x9” with 245/35/19 tires front and 19x10” w/ 265/35/19 tires rear
    * Rack-and-pinion steering with hydralic power steering (Servotronic)
    ENGINE/TRANSMISSION:
    * Free revving twin-turbocharged, all aluminum, 3.0L inline 6 cylinder engine, with direct injection
    * 335hp @ 5900rpm
    * 332lb-ft torque from 1500-4500rpm (with +37lb-ft overboost)
    * 7,000 rpm redline
    * 4.7 second 0-60mph / 4.9 second 0-100kmh
    * 13.2 second quarter mile
    * 155mph top speed
    * M Drive button actives razor sharp throttle response program
    * 6-speed manual transmission with dry sump cooling system and 3.15:1 final drive ratio, with M gearshift knob
    * Upgraded flywheel for use with high torque
    M DIFFERENTIAL / TRACTION CONTROL:
    * Variable M differential lock for optimum rear wheel drive traction
    * DSC traction control
    * MDM (M Dynamic Mode) mode allows less intervention from DSC system for more oversteer and maximum performance
    AERODYNAMICS: AIR CURTAINS
    * Air curtains, used here for the first time in a BMW production vehicle, improve air flow around the wheel arches with the benefit of significantly reduced turbulence. This innovative aerodynamic feature consists of openings in the outer section of the lower front fascia that route high-pressure air through ducts at each front corner. The ducts are approximately 10 x 3 centimeters wide and are designed to channel air to openings at the front of each wheel arch, where it is discharged through a very narrow opening at high speed. The escaping air stream covers the side of the front wheels like a curtain, thereby reducing aerodynamically unfavorable turbulence around the rotating wheels. (Technology stems from BMW Vision Efficientdynamics).
    Info from Bimmerpost
  6. detailersdomain
  7. Wes_R
    Wes_R Birth of a Detailer
    Next car Phil?
  8. detailersdomain
  9. domino
    domino Welcome to Detailing
    it still looks too girly in the front
    but i do applaude them getting closer to the original e30 m3 concept
    i dont understand the reference to 10 seconds quicker than the e46 m3. So BMW are saying it's taken them 10 years and a couple turbos to gain 10 seconds on an 8 minute circuit..... i wouldnt be bragging about that
  10. luke093
    luke093 Welcome to Detailing
    I think what they were trying to get at, is the two have similar power and close weight, so as good as the e46 handled, this is a potent little monster :p
  11. 2KLS1
    2KLS1 Birth of a Detailer
    Yes it will be, as long as you don't get an HPFP failure.
  12. domino
    well yeh it looks like the 1M is based on the original twin turbo N54 that had the fuel pump class action suit...... soon after BMW scraped it for the single turbo N55
  13. 2KLS1
    Well from what I've read the N55 isn't completely immune to the same problem. It's a shame too because aside from killing fuel pumps it seems like a great engine.
  14. v|nsan|ty
    v|nsan|ty Obsessive Detailer
    I still hate the look of the 1 series even with the added changes. I rather drive a better looking car that is slower
  15. dr.jay
    dr.jay Birth of a Detailer
    Just bought a 2011 135, I cant picture this thing being any faster than it already is. This is the first turbo'd car I have ever owned and I plan on keeping it a very long time. I got it with the DCT tranny from the M3 and the gear change is nothing short of amazing. I've had an E46 330ci, E46 M3, 3 X5's (1 3.0 and 2 4.4's) E60 M5 and this is by far my favorite BMW I have ever owned. M5 was outstanding in the acceleration department but city driving was no so good with SMG, it was very jerky.
  16. SpecC
    SpecC Wax on..Wax off
    looks like it ate a lot of steroids
    also since it's a turbo, it's going to be fantastically easy to tune
  17. domino
  18. pushtiulk
    pushtiulk Guest
    amazing car. to bad that they don't make it with smg trans also.
  19. jbate
    jbate Virgin Detailer
    They are not making enough of these.
    I'm pretty sure this is going to be a limited production model.
