Optimum Opti-Mitt 8 Inch Foam Wash Mitt
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by oldcracker, Nov 20, 2010.
  1. oldcracker
    oldcracker Jedi Nuba
    what do you guys think?
  2. TWISTEDFRAME
    TWISTEDFRAME Jedi Nuba
    [​IMG]looks almost identical to the schmitt, which I have but never really use. It's not a bad product, I just like other products better for one reason or another.
  3. billyblooshoes
    Looks like a black 3M pad with a sleeve for your hand.
  4. domino
    domino Welcome to Detailing
    yep +1 on the schmitt
    i bought one a while ago to try out and didnt really like it - too big and doesnt get into corners as well as a sponge/mitt
  5. oldcracker
    hmm, this is what Chris from Optimum said on the Optimum forums
    The foam and color are different from the Schmitt and exclusive to Opti Mitt. It is comparable to a finish pad with about 90-100 ppi. I believe the Schmitt is 70-80 ppi. The color was specifically chosen to conceal the staining that naturally occurs over time with any wash media.
  6. mobilejay
    mobilejay Birth of a Detailer
    I may try one of those out. I have the Schmitt and it's all I've used for 3 years. I love it
  7. GDAL
    GDAL Guest
    I bought several schmitts when I first started detailing ... they don't last long and they are not soft enough to "hug" the panels while washing. I remember washing panels at least twice because it was so easy to miss a spot with the stiff foam. The foam around the glue that hold both sides together usually gives after a few months.
  8. kdude
    kdude Jedi Nuba
    I like the Schmitts... I may try the Opti since its a bit easier on the paint..
  9. JRogers
    JRogers Virgin Detailer
    grout sponge from Lowe's ftw.
  10. Emile
    Emile Welcome to Detailing
    +1. The softer foam may make it more flexible as well. But not sure since the. Back side still has the stiff scrubber side.
  11. Chris@Optimum
    Chris@Optimum DB Certified Manufacturer
    It is not THAT stiff. It's safe with light pressure. I had a couple of the beta mitts to test.
  12. P1et
    OH NO it has another 10 ppi and it's a different color? WELLLLLL then it's NOTHING like a ShMITT whatsoever, I cannot believe you all thought it had ANYTHING in common with the ShMITT whatsoever! you guys are so dumb...
  13. TWISTEDFRAME
    ^made me :giggle:
  14. Chris@Optimum
    The difference between a polishing and a finishing pad is only 10ppi.
  15. rwisejr
    rwisejr DB Forum Supporter
    Sure looks like a schmitt to me . I really liked it myself. But as Gdal already posted the pocket always seperated to easy. . I have since moved on the the Uber sponge .As it fits my needs greatly.
