so today im doing a little claying using my adamsq/d in my kwazar spray bottle i gotfrom phil. and the more i use these the more trilled i am with them. even though there pricey there well worth the money. the double pump trigger is a must. it will save your hands gid time. i dont think ill ever go back to cheap spray bottles again its kwazar all the way !!!!!!!!!!!!if you guys havnt tryed one yet you should. there great very heavy duty too!!!
i keep chasing tom around these forums to agree on the bottles. just got 6 of the 1/2 liter ones and like them even better. put some glass cleaner in it and promoted it at a gtg in portland , or. most people miss the weighted bottom which is significant too. thanks to phil for the priceing
I love mine. I bought a 6-pack, but I'm only using three at the moment. ONR clay lube, Sonax and OPT Power Clean. They are someone for applications that need fast coverage. These things really reduce fatigue on your hands.
Highest quality spray bottle there is, the trigger has no flex and is very solid and the bottle is very rigid with a wide bottom. They are pricey but well worth it, plus the have graduation marks to make dilution a very quick and easy.
I'm also really loving these bottles, I discovered the double action means I can just "jiggle" the trigger pulling it about a 1/4 stroke rapidly to produce a constant fine mist. Then I just quickly wave it across a panel and you get really even and fast coverage. I also like that as soon as you pull on the trigger there is flow with no dead zone or priming. Only complaint is the very narrow neck wich makes filling slightly tricky but I use funnels most of the time. Also the 1L bottle tends to get a little "bottom heavy" if you use it allot but the 500 ml ones are perfect. I thought my Delta sprayers were great but now I've been enlightened, never thought a spray bottle could be so enjoyable. Whenever I use the Delta bottles I want to throw them across the room!
Ya they should but you probably should run water through after using it because viton seals can fail with wheelbrightner
i stumbled across these exact bottles in a local hardware store here in Aus, not branded kwazar though and in a fluero orange color scheme and i agree, great bottles, though they use a fair bit of product - im used to the never ending story p21s wheel spray bottle they were hella expensive here, i paid 19.95 AUD for one 1L bottle
i just got the smaller ones .5 litter perfect size . i use the larger one for waterless wash.1 litter
they only had the 1L and then a few of these massive containers with a pump handle and hose had to give it a shot im using it to spray my CG Orange Degreaser under wheel arches each wash - easiest way im finding to clean the plastic guard linings
Given the massive output you can get from these sprayers, what would the benefits of the hand pump spray offer (Venus model and other brands)? I've been on the look out for two hand pump sprayers for using ONR for clay lube/pre-spray waterless wash, but I figure I could just buy a 6 pack of these spray bottles instead and then I could use the other spray bottles for your typical spray duties.
The hand pump ones are Viton sealed, so suitable for the likes of brake cleaner, etc. Nothing unique like the trigger heads, but some people like to have everything the same, or the confidence the brand instils in them.
Aren't the trigger heads also made of viton rubber? I think I might purchase them just to try it out. I have not been able to find any decent hand pump sprayers locally, and they're all much too big.
