dsms detail - Beefy Correction on Hammered LS460
Discussion in 'Professional Detailer's Studio' started by dsms, Sep 11, 2010.
  1. dsms
    dsms DB Forum Supporter
    Lexus LS 460L in for an extensive paint correction and interior detail.
    Majority of the paint issues came from automatic car washes and later a paint chip repair guy who attempted some "buffing" of his own, naturally that only added to the issues.
    This writeup contains lots of 50/50 pictures and several videos including one on DA wetsanding.
    Prep procedure:
    Pressure rinse
    Foam
    2 bucket wash using strong mix of CG citrus wash
    Riccardo clay + ONR lube
    Multiple IPA wipedowns to completely strip paint of old glaze
    Wheels:
    Sonax on wheels
    Powerclean on tires/wheel wells
    Started with the hood, many rock chips attempted to be fixed on the hood and more damage was left than damage fixed
    Closeup of defects under Fenix LED
    After M105 + wool pad and Menzerna Powerfinish
    Wool compounding
    Front fender corrected, door uncorrected
    Trunk section was too damaged for high level correction using even a wool pad and M105, no sense in even testing out that combination as I would have yielded no more than maybe 75% correction, the gouges and deep rids would be left all over the trunk. In trying to chase down those very deep defects with a wool pad at high RPM I would most likely remove more clear coat than I would like to in the process.
    So I opted to wetsand it instead. The entire trunk was DA sanded using 3000 grit discs
    Lots of deep RIDS and gouges, again rock chip repair was attempted here and failed miserably.
    Before beginning prep on the trunk I let the paper soak for about 40 minutes in lukewarm water
    Two 3000grit discs soaking before using
    Proper adapter screwed into backing plate for sanding, then the backing pad was put on
    Finally after soaking, disc was centered on. I used 1 disc for the right side, and 1 disc for the left side after which both were thrown away.
    Slurry left in the process of sanding, water in a sprayer bottled had a tiny bit of pH car soap for lubricity, some like that some dont, I prefer it. Not a ton of water used in this process so I guess you could classify it as "damp sanding" rather than wet sanding.
    Readings taken after also
    DA sanding Video
    YouTube - Machine Wetsanding by Street Dreams Detail
    Results and 50/50s after removing sanding marks with the same black wool pad and M105 combo plus foam compounding with Powerfinish, no finishing polish at this point
    I like this picture because it shows the natural color of the finish with the heavy concentration of swirls compared to the sanded and polished side
    Left side then sanded also
    Onto the rest of the car
    The doors had some of the heaviest concentrations of swirls I have seen so far on any car
    The 3 lightsource test.. if it passes this you achieved what you wanted.
    - Halogen
    - LED
    - Camera Flash
    Uncorrected under 3 different light sources
    Corrected side under the same 3 light sources
    Video 50/50
    YouTube - Street Dreams Detail - Video 50/50 Before and After polishing
    Closeup
    Drivers side door, same issues
    Mirror
    After all compounding and polishing work the car was finished using the DA and Menzerna PO85rd. Lexus paint is very nice to work with but can be a bit of a pain to finish down via rotary so before taking any chances I switched down to the DA and it worked great.
    I'll open up a door or pop a hood so I can polish all the way to an edge without spilling over on the next panel...
    Like I did here
    After gentle finishing and some more inspection after another IPA wipedown I pulled the car outside to double check my work in the sun. No LSP applied yet
    Sun shots after correction only
    Trunk, nice and leveled
    Back inside for interior work
    Before
    After
    Doorjambs sealed using Opti seal
    LSP: Powerlock x2 applied by machine
    Inside for the final wipedown using distilled water
    Final shots
    Trunk as I imagined it would look after the time spent on it
    Hood reflection
    Walkaround video
    YouTube - Street Dreams Detail - Lexus LS 460 After Massive Correction
    I usually keep my favorite picture for last, one that sums up the detail as a whole...in this case it was not a finished shot but a 50/50 of the trunk...
    Thats it, thanks for looking!
  2. GDAL
    GDAL Guest
    Great work as usual dave ... I need to try wetsanding with a DA soon.
  3. Chas
    Chas DB Forum Supporter
    Awesome work Dave! G, I can try and bring a scrap panel when we meet up and we can both try it out with our DA's.
  4. 911Fanatic
    Holy crap David. That was freakin' nasty!
  5. Frankastic
    damn.......................
  6. stottie
    stottie Birth of a Detailer
    insane, man thats awsome work. great job. also thanks for showing the video of wet sanding
  7. nyrep1
    nyrep1 Obsessive Detailer
    make me want to hang up my buffer and donate all my polishes
  8. Denzil
    Great work Dave, that Lexus was really trashed!
  9. Marc08EX
    Marc08EX Jedi Nuba
    Great job as always! How long did the process take you? Seems like a lot of surface area to cover.
  10. Brynjar
    Brynjar Birth of a Detailer
    Very nice work Dave, the car came out looking spot on:)
    Great write-up to!
  11. D&D Auto Detailing
    Great job Dave, looks awesome!
  12. mutmanns
    mutmanns DB Forum Supporter
    Very impressive detail and write up.
    Your writeups is what got one of my friends to join this site and to start taking better care of his black car.
    Did you do a polishing step between the compound and finishing polish?
  13. Mindflux
    Mindflux Welcome to Detailing
    Interesting. I would have thought the longer stroke on the Griots polisher wouldn't have made it ideal for wet sanding. (The Megs and PC have a shorter stroke).
    Looks good!
  14. billyblooshoes
    nice work david. thats a lot of real estate to cover on the LS series
  15. Max405
    Max405 DB Forum Supporter
    David,
    I am most impressed with your work. You are such a pro, it is astounding.
    Treat yourself to a Filet and Lyonaisse potatoes at Ruths Chris. You deserve it!
    Incredible.
    Joe D
  16. Wheelz25
    Wheelz25 Jedi Nuba
    Awesome detail, the completed shots look unbelievable....I really dislike that black lexus paint. To me it seems similiar to the BMW Jet black. It's so soft and seems every black lexus on the road looks like that...well except this one now.
    Great job
  17. rwisejr
    rwisejr DB Forum Supporter
    Fantastic work Dave . Love the finished product.
  18. wise 85
    wise 85 Virgin Detailer
    Awesome work David,you set the bench mark standards for attention to detail,look forward to reading more of your enjoyable writeups.
  19. Rennes
    Rennes Jedi Nuba
    wow and wow.
    Can't say how pro your details are, as usual :)
  20. detailersdomain
