1. edwinbong
    edwinbong DB Forum Supporter
    anyone have both types of green pads? Coarse Green Cutting/Polishing vs Green Polishing/Finishing Foam. I have some green pads which feel similar to my yellow cutting pads and wasn't sure which was which. so was wondering if you guys had any photos that could help distinguish what pads i have.
  2. porta
    porta Jedi Nuba
    Sounds like you have the foam that EDGE and LC are using. They are heavy polishing pads with open cells, and feels a little bit rough.
  3. pektel
    pektel DB Forum Supporter
    +1. I don't like those. They feel like a scotch brite pad.
  4. Bunky
    Bunky Guest
    This is the two Lake Country pads..
  5. bigfoot
    bigfoot Jedi Nuba
    I have the coarse one, which is perfect for AIO type products
  6. togwt
    Patent pending, Collapsed Cell Structure (CCS) Technologyâ„¢, Euro foam from Raisins Schaumstoffe, Gmbh., Germany developed for and used by Mercedes-Benz These pads are manufactured from thermally reticulated, urethane foam with an open cell structure.
    I think the other 'Green' foam was re-labelled for Autogeek
