Exterior Plastic Dressing ???s
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by slanguage, Jan 25, 2010.
  1. slanguage
    Ok.
    So we all know keeping exterior plastics looking good can be a royal PITA, especially the piece under the windscreen wipers.
    So my question is this. Which ones work the best/last the longest?
    I know proper cleaning is key, and found that cleaning them with Meg's APC seems to work pretty well for me.
    I have tried Black Wow in the past, but wasn't fond of the product.
    These are the current products I have that can be considered for opinions:
    1Z Vinyl/Rubber Protectant
    CG BareBones
    303 Aerospace Protectant
    Stoner's Trim Shine
    Meguiar's HyperDressing
    Your thoughts/experiences/opinions/results/techniques would be greatly appreciated!!
    Thanks,
    -Roger.
  2. Reflect
    I think Optimum makes one that works really well but I haven't tried it.
  3. agpatel
    1z deep plastic cleaner is great for cleaning plastic before applying dressing. I have found it works a little better than APC.
    I just got some Megs Ultimate protectant and seeing how it works out. I am using black wow currently on my cowl area and what not so be interested in ho Megs stuff ($10/bottle) holds up to black wowo.
    I know Supercharged likes ultima trim sealant/dressing.
  4. slanguage
    ultima seems a bit pricey. but waiting to see what other people say 1st.
  5. kustomizingkid
    kustomizingkid Nuba Guru
    Black Wow lasts the longest...
    I use Megs #40 for looks on my stuff...
  6. pektel
    pektel DB Forum Supporter
    add another one for meg's 40. I like it. I use black wow if I have the time.
    Has anyone tried KAIO on it? I've used it on glossy black cowl areas with good results, but haven't tried it on the textured variety.
  7. krshultz
    krshultz Nuba Guru
    Vinylex works pretty well as dressings go. I'm not sure it's any better than Trim Shine, though. Trim Shine seems to last reasonably well.
    The only process I've used that I've found to be 100% satisfactory is removing the trim and redying it. I did that with some parts on my F250. That page shows my mirrors, but I did the cowl that way too. It's not always a practical solution, but if you can remove the trim in question, I think it's the way to go.
  8. Aesop
    Aesop Jedi Nuba
    I love Gloss It's TRV. It is absolutely awesome and its a creme so it does not run everywhere. It a water base product too, so no oily residue if you miss.
  9. GDAL
    GDAL Guest
    Roger I use Stoner's Trim Shine most of the time. I use Black Wow when the trim is really bad and I have the extra time.
    I think the key is how clean the area is before the application. Apply Trim Shine and let it sit under the sun for an hour or two. Buffing the residue with a MF should give you a nice matte finish.
  10. slanguage
    yeah. i do like the trim shine a lot myself. i might have to try the deep plastic cleaner instead of the apc and see how that pans out for me.
  11. supercharged
    Ultima trim guard plus is worth it...outlasts everything...
  12. TONY MONTANA
    TONY MONTANA DB Forum Supporter
    pro blue ice lasts a while but i think black wow is the best
  13. richy
    I use either 303 or the DG trim dressing or their marine version.
  14. Legacy99
    Legacy99 Wax on..Wax off
    I agree you can throw out Megs and Black Wow. Have you tried it out on tires?
  15. Denzil
    I've used PB's Trim Restorer and Black Wow with great results. I've used 303 AP in the past but haven't recently used it to remind me of how well it works.
    With PB's Trim Restorer, multiple applications are key.
  16. togwt
    Clean surface with Iz einszett 'Plastik-Reiniger' and apply a suitable matte type dressing (G Techniq C4 Trim Restorer
  17. supercharged
    Oh, Yeah! Because it just lasts and lasts and lasts...Very well worth it...
    It's worth it, Roger...One bottle will last you a long time, because you use so little, and application lasts quite a while...
    I would throw away BW, I'd use it up, and not buy anymore...afterall it is $25 for a small bottle...No I haven't tried it on tires, I love Tropi-care (showroom FX) white pearl so much, that's all I use on tires...
  18. supercharged
    you should try Ultima Trim Guard Plus, it outlast Poorboy's and Black Wow...
  19. kustomizingkid
    I'm really interested in seeing how the optimum coating lasts on the trim... that would be awesome if you could keep your trim looking great for a year at a time...
  20. anbuzero
    anbuzero DB Pro Supporter
    trim shine surprised me, i tried it out on my mother in laws truck and its still good. i have 303 and CG Silk and Shine that do a pretty good job
