7424XP to cut polish wetsanding?
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by kc1337, Jan 5, 2010.
  1. kc1337
    kc1337 Obsessive Detailer
    So i've been wanting to hold off wet sanding my car to fix a scratch since I am not quite sure if the PC with PowerGloss and Yellow pads will have enough power to polish out 2000grit sand paper marks.
    Anyone got any opinions?
  2. eyezack87
    eyezack87 Guest
    Yes, it will be no problem. I've removed 1500 grit from a Jet Black BMW before with my normal PC. You just have to figure out the technique for it. I normally use orange + Power Gloss for mine though. Yellow leaves too much marring in my experience
  3. Legacy99
    Legacy99 Wax on..Wax off
    Sure it will, but why not finish down with 3000 grit?
  4. 911Fanatic
    I agree. The LC Yellow is very abrasive. I'd suggest the orange/Power gloss combo as well.
  5. Darkstar752
    Darkstar752 Horizon Detailing
    Sanding scratches are easier to remove then you think. It's not even a matter of if you can, just how long it will take. Taking off 1,500 and 2000 are pretty much the same, it only takes a couple seconds on rotary to remove the haze then it's cutting a bit more and refining. Don't be scared of it.
  6. kustomizingkid
    kustomizingkid Nuba Guru
    Just don't get stupid with your wet sanding... a hard backing on the paper helps avoid putting deep finger marks in... light pressure!
  7. agpatel
    It should remove it, if you can get some 3000 grit it will make it even easier to remove the scratches. SIP and orange pad can remove 3000 grit pretty easily with a DA.
  8. alexd10
    alexd10 Any Rag Vehicle Washer
    Yes, from my experience, I've easily removed 1500 grit sand marks with M105 and Sonus yellow pad.
  9. Misha
    Misha Nuba Guru
    well it does more couse its powergloss. maybe try SIP with 2 passes. i did wetsanding then powergloss and then 203 and works fine
  10. togwt
    Using a PC to wet-sand
    1500 >2000> 3000 grit 3M Perfect-It Trizact speed 3 -4 .Remove sanding scratches with a suitable finishing polish
  11. kc1337
    I got 2 sheets of 3M 2500grit sandpaper.
