sealing flat black paint
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by richy, Nov 25, 2009.
  1. richy
    I have a Mustang coming on Friday that has flat black paint on the hood and rear deck lid. The customer wants the paint sealed but I'm afraid that if I put DG 105 on it then it may cause the paint to have some gloss which obviously I don't want. Has anyone had any experience with flat paint? Can it be buffed or will that induce a shine?
  2. togwt
    Matte or Satin Finish Paint
    Do not polish or wet-sand a matte clear, as the flattening agents that cause the matte appearance (textured finish) by diffuse reflection are retained very close to the surface. By levelling the surface the light will be reflected evenly and result in a ‘shine’. Use a rotary polisher and an ultra soft, zero abrasive cut (Lake County CCS Concourse Gold (100 PPI) foam pad) with a mild chemical paint cleaner/ polish (Zaino Z-AIO - All in One) it will remove surface marring and leave it flat and dull. Use a clear polymer (Zaino Z-CS - Clear Seal) to provide surface protection
  3. 911Fanatic
    Dont get any kind of polish near the flat paint. It'll put a shine on it instantly. I would even go so far as to tape it off if you are polishing around it.
  4. agpatel
    Opt Opti-Seal is what I use on flat black vinyl and does nothing to the sheet of it.
  5. richy
    Thanks for the responses.
  6. yakky
    yakky Two Bucket System Washer
    On Jeep hardtops, I have had good luck using Zymol Carbon. It makes the surface just a bit less flat, but it still looked good, just something to think about.
  7. agpatel
    Know this is a little out of the scope, price wise, but I tried Swissvax Insignis on my flat black vinly and it did not change the look at all. Ketil said it would work well on matte paints so I tested it out and came out looking good on test samples.
  8. richy
    If you guys saw my post on the "awesome mustang", you saw that I used DG 501 with great success.
