I believe this Panamera Turbo is the first one in Southern California and it was a real joy to work on. First, this is one AMAZING Porsche. I liked it on paper and on the computer screen and now I'm in love with this sedan. IMHO, it's hands down THE sedan of choice for me at the moment. The fit and finish is second to none. The attention to detail and design is second to none. Porsche definitely did its homework and hit it out of the park with this one. As you'll see, this Panamera did come with the usual flaws from the dealer. I can only assume it was from washing the car. How a dealer can send out a $150000 car in this condition is beyond me. To this day I have yet to find a dealer do a proper prep on a new car. It infuriates me to no end; but that's another thread. This detail was suppose to be a full interior/exterior detail but once I started, I decided to shift gears. The client is going to take this car to a few runs before taking it to SEMA in a few weeks. I originally wanted to do a paint correction as well as a full detail but the client was hesitant on machine polishing since he knew the car would get hammered in the next few weeks. I thought I could simply hand polish the exterior and minimize some of the imperfection. To my dismay, hand polishing didn't get me the desired effect. Knowing how special this car is and the attention it was to receive, and my rep being on the line, I decided to do a one-stage polish instead of a full interior detail. This way I'd stay within budget, stay within time allocation, and make a dramatic improvement in the overall appearance of this car. I'd say the exterior is about 85% of the way there, but I'm very happy considering the circumstances. With that said, here's an education on our process at Glistening Perfection and what we feel to be a proper New Car Prep. Initial Condition
Initial Wash (90 Minutes) I first begin by cleaning the door jams using a citrus-based cleaner. This helps loosen the dirt and grime in the door jams and seals Door jams rinsed with deionized water Then the engine bay is cleaned using same citrus cleaner. The trick to remember is to run the engine for a while to warm up. Rinse using deionized so there's no water spotting. Use a soft horse-hair bristle to clean components Then the engine bay is rinsed using deionized water Wheels are cleaned using a safe pH balanced wheel cleaner that will not harm the clear coating on the wheels. Various brushes are needed such as horse-hair wheel brush and the EZ Detail brush to get inside the wheels and clean in the wheel well Then wheels and wheel well are rinsed using deionized water The exterior is rinsed, washed using an organic and natural auto soap that is safe for the paint and the environment. My choice for a wash mitt is the GP Australian Sheepskin Mitt. I work in small panels, washing area no larger than where my arms can reach. Once the panel is washed with the mitt, I then rinse the panel washed and rinse the mitt. This way, the paint is flushed from the soap that is holding all the dirt and my mitt is always clean when dipped back into my soap bucket The paint is dried using our GP MicroDry Towels. These are high-quality foam-core microfiber towels that do an excellent job of drying. Two towels is enough to dry the whole car. I then blow-dry the exterior to get all the water out of the nook-and-crannies using an Airmax Filtered Blower
Paint cleaned and decontaminated (20 Minutes) Now that paint is washed and dried, it's time to decontaminate and deep clean the paint to prep for polishing. This wasn't all that bad as you can see not much contaminants were picked up by the clay. A very mild clay was used Paint is polished to remove imperfections and prep for wax (180 Minutes) As I mentioned, I ended up doing a one-stage polish using Menzerna Super Intensive Polish and GP CCS White polishing pad using a FLEX at setting 5.5. The results were stunning considering a one stage process. The panels were wiped with alcohol to assure proper correction Polishing is complete. You can see how the polish is broken down and has a slight haze that can almost be seen through Final polishing results prior to waxing Exterior is waxed using a carnauba wax (20 Minutes) Final attention is addressed to tires, wheel well, and wheels (30 Minutes) Door jams are waxed, engine bay is wiped down and conditioned, any rubber trim is cleaned and conditioned (30 Minutes) Glass is cleaned and Final Inspection is done (15 Minutes) Interior is vacuumed, leather is cleaned using Organic Natural Leather Cleaner. All interior panels were then conditioned using a spray that applies a UV coating to protect against sun. We will condition the interior in a few weeks with the proper leather and vinyl conditioner. (50 Minutes)
Final Results Slight haze you may see is from the wax. I had to apply the wax on the hood in direct sunlight and since I used a carnauba wax, it has a lower melting point than the paint temp at time of application. No matter what you do, the wiping will leave a slight haze until the paint is cooled down and wiped
Thanks to the client, will remain anonymous, and the boys at BBI, Betim and Joey. You guys were great to hang out with and your facility and dedication is second to none. I appreciate you accommodating me and making me feel at home. Glad we had a chance to finally meet and I look forward to many more details at your facility. Appreciate you guys checking out this thread
very nice. seen this one last weekend when was in VA, not sure if it was turbo since just seen it going other direction on highway
What's the company who's url shows on the last few images??? And, can you have your company name on these images???
nice work. although im still waiting for the look of this car to grow on me, as far as performance and the interior goes, if i had to buy a sedan for daily driving and price was out of the question, i would probably get the panamera turbo. we just got one in where i work, just a plain jane panamera 4.8. still really nice though.
I agree this is an AWESOME sedan ubut not my choice at the moment. I istill am in love with the Maserati Quattroportte Automatic that thing is aaaaamazing Great work thought The final pics are how it should come from the factory
yeh as the others said you should take out the part with your business name and links, only sponsors are allowed to advertise on the forum and Nica will probably take your whole thread down other wise nice writeup :thumb:
Thanks for checking this thread out fellas. I've contacted Nicca about sponsorship as I wasn't aware of the company info rules here. It was late in the day, started making this thread around midnight and didn't finish until 5:30 in the morning. We do sponsor 4 other forums so posting it across the boards wore me out. I figured you guys would appreciate the efforts to bringing this amazing car back to the way we all know it should have left the dealer. Anyway, enjoy the post and we'll make our sponsorship here on DB official shortly. Cheers.
Thank you Sir for the compliment. I wonder if Porsche has any ideas their cars are being delivered this way to clients. I would be livid if my car was delivered this way. The Maserati is nice, but I found the attention to detail in this panamera to be better. The materials porsche used such as the aluminum in the interior and marrying the leather to the shift knob with the aluminum are where you can truly see how well-built this car is. I only hope it doesn't tank in price like the Mas...then it again it wouldn't be so bad...we all could at least consider owning one. :giggle:
EDIT: Whoops, didn't see your response about the sponsorship on the 2nd page. Great work, and amazing car! It must be nice to work on such exclusive cars.
No worries...I've got our web guy making the changes right now. I don't want a little mishap to take away from the actual work and the car. New pics without any company info should be up shortly
woooow u have got a close up on that beauty ...wat a popular choice black ..im sure u will be seeing it again ..very good job thumb up on your washing techniques :headbang: ..keep up the good work
OK guys...fixed the pictures so now you can simply enjoy the thread and critique the heck out of my work
