water spots are narly!!!
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by bimmer nation, Oct 10, 2009.
  1. bimmer nation
    bimmer nation Birth of a Detailer
    hey guys so one of my customers has a 66 cady that he has kind of restored. its beautiful other than the widows. There are the worst water spots i have ever seen in my life like by far the worst. I tried polishing with compounds, and everything and all it did was smooth the glass out. it took some away but not much at all. I guess my question is can i wetsand glass?? if not is there any other solutions???
  2. kaiten408
    kaiten408 Jedi Nuba
    I don't know about the wetsanding, but have you tried claying the glass with some aggressive clay?
    There's the vinegar trick too. Not sure if you have tried these already.
    Good luck
  3. TONY MONTANA
    TONY MONTANA DB Forum Supporter
    did you try a water spot remover?
  4. Ian
    Ian Jedi Nuba
    DO NOT wet sand glass! you can actually shatter glass by doing that. I know many people have tried buffing/polishing glas but you can break/shatter the glass that way also
  5. 911Fanatic
    I have had great success with DG NU GLASS lately. Has removed all the water spots on 3 different cars when applied with a MF applicator pad. Worth looking into. I carry it if you are interested.
  6. kustomizingkid
    kustomizingkid Nuba Guru
    CG water spot remover?
  7. dino
    dino Virgin Detailer
    Have you tried M04 with a rotary and wool pad? Can you post pics of the waterspots?
  8. Bunky
    Bunky Guest
    What is the consistency of Nu Glass?
    I had picked up some DP Glass Restorer. It has watery polish that feels gritty.
  9. bimmer nation
    ok so no wetsanding thats wat i thought haha and no i havent tried the vinegar trick. tried clay that didnt work but then again it wasnt aggresive so ill give that a try and i guess i need to grab some water spot remover. and i will take pics next time i see it lets just say it sat in a field for 15 years before he picked it up so they have been baked in for years
    thanx guys
    and does that nu glass work really well???
