Got Bored, Mixed Up Some Wax
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by Dsoto87, Sep 13, 2009.
  1. Dsoto87
    Dsoto87 Jedi Nuba
    So Im sittin here bored on a sunday night looking at my various detailing products when I noticed some samples of wax I got from denzils last sale. I had previously tried some of them out already and new that I probably wasnt going to get another chance to try them since I still have other stuff that I havent used.
    Thats when I got the idea to mix them. Superwax perhaps? :shead:
    Anyways, heres the 5 different waxes that went into the mix
    Lusso Oro
    CG 50/50
    CG Petes 53
    M16
    476s
    I just basically sat them in a pot of boiling water and let them turn into a liquid, than I poured them all into a bigger seperate container.
    I dont know what it means or if its relevant but M16 was the first to melt, than 476, than 5050 and Petes 53 and LO were last.
    Its only been cooling for about an hour now and its still pretty soft. We'll see how it goes
  2. agpatel
    Nice, always fun playing with mixing wax's up. Cant wait to see some pics.
  3. Gemini13
    Gemini13 Obsessive Detailer
    What kind of containers were those you boiled them in?
  4. BrendanS
    BrendanS Welcome to Detailing
    you shouldve gotten AB in there haha, it would be cool if you got the masking part of AB in that bunch. Looks like fun though, let us know how it goes
  5. agpatel
    Not a good idea to mix a sealant in with the nuba, it would not work very well, haha.
  6. Duratys
    Duratys Welcome to Detailing
    Wouldnt the solvents in the wax be gone after boiling them?
  7. supercharged
    let me know how it will come up.
  8. Legacy99
    Legacy99 Wax on..Wax off
    Hope you dont end up with oil and wax separated.
  9. agpatel
    No not really, only a small amount of them will burn off but as long as you keep the heat low you will be fine.
  10. Dsoto87
    Dsoto87 Jedi Nuba
    I scraped some off the edge of the outer rim (outside, not inside) of the container and applied it to a license plate cover I had. I let it dry for about 20 minutes. Holy crap the stuff was hard to remove. I dont know if that was the complete mixture though. It might have been just 476 or m16 that was on the outer rim. I havent tried the actual mixture yet.
    BTW ive melted other waxes and never ended up with just oil and wax seperated. As you can see in the last picture its solidified again.
    Those containers are from Denzil. He sent them like that
    I believe some of the solvent may evaporate off but not enough to make a noticeable difference.
    I did this with some nattys red because the container cracked and saw no real difference in application or removal
  11. froboy272
    froboy272 Obsessive Detailer
    did you get to try the wax yet dsoto?
  12. detaildoc
    detaildoc Guest
    I wonder how RBOE with Victoria Red and Souveran would look?
  13. Dsoto87
    Dsoto87 Jedi Nuba
    No not yet, but I should soon because it looks like the weather is going to be nice for a few days here. Maybe tomorrow.
    send me a couple oz of each and ill let you know ;)
  14. agpatel
    Someone over on autopia mixed #16 with some polycharger to see how it would effect it. Hmm, I have a few wax samples that are just laying around may have to play around this weekend.
  15. Dsoto87
    Dsoto87 Jedi Nuba
    I have some polycharger, I should have put a few drops in. i didnt even think of that at the time.
  16. agpatel
    maybe you can melt some of this stuff and add a few drops, you have the CH version? Dont know how long it will last after you polycharge so maybe a small amount, 20-30 mL
  17. Dsoto87
    Dsoto87 Jedi Nuba
    Yea I have both versions. Ill give it a try. Ill just follow the dosing instructions for the liquid waxes, I think its 2 doses per oz
  18. edwinbong
    edwinbong DB Forum Supporter
    sounds interesting
