polishing black paint
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by junbug, May 27, 2009.
  1. junbug
    junbug Virgin Detailer
    dont have much experience cut polishing black paint, so i got my friend 2 let me practice on his truck. having a hard time keeping swirl marks out, just when i get them out and i think i'm good a couple steps back reveals new ones....frustrating. please help
  2. DaveS4
    DaveS4 Jedi Nuba
    What polish / pads / machine are you using?
  3. junbug
    polish- megs #2 with a w7000 foam pad followed by megs #9 with w9000 foam pad and a CP air polisher
  4. DaveS4
    DaveS4 Jedi Nuba
    Ok. Care to elaborate on your process a bit? Speeds, steps, etc.
  5. junbug
    also, he has some pretty bad scoring on the tailgate...recommendation for wool pad/polish combo
  6. DaveS4
    DaveS4 Jedi Nuba
    Lake Country Purple Foamed Wool pad and M105 since you seem to like Meguiar's...
  7. junbug
    theres no set speeds on the rotary, but i try 2 feather the variable trigger at about 1/3 to 1/4 power. as far as steps, just priming my pads with polish, applying small amounts of polish 2 body, spread it over the area then polish it down till i start getting a bit of shine back
  8. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    What pads and polishes are you using, what is the condition of the paint. I enjoy polishing black vehicles.
  9. Nica
    :nod: Black colour vehicles are extremely rewarding when detailed properly.
    There is lots to polish a vehicle, first of all what make is the vehicle? That will determine the clear coat your up against and should also help you choose a polishing combo. Example, Toyota has soft clear coat so if you use an aggressive combo your going to leave and induce more swirls/holograms.
    Hope this helps.
  10. junbug
    is there a referance guide 4 the hardness of the clear coats of different manufacturers? and i understand that rpm's r a factor as well, whats a good rotary that has speed settings so i dont have 2 keep trying 2 feather the variable trigger on my air polisher
  11. DaveS4
    DaveS4 Jedi Nuba
    The Makita 9227 CX3 seems to be the fan-favorite. I have one and love it!
  12. Dream Machines
    Dream Machines Jedi Nuba
    this is what I have found
    Jap paints - soft to very soft
    Australian - medium
    European non ceramiclear - soft to soft/medium
    European ceramiclear - hard to very hard
    American paint - soft, medium and rock hard
    Dodge nitro - medium, Ford GT softer, Corvette rock hard
