noob question
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by forcefedm3, Mar 10, 2009.
  1. forcefedm3
    forcefedm3 Any Rag Vehicle Washer
    what do i do after i have finish polishing a vehicle? not sure what steps to take.
    kevin
  2. billyblooshoes
    do an IPA wipedown of the car to check for true correction, then wash the vehicle once again to remove any residual. make sure you empty your wash buckets and use clean water. be sure to flood those panel gaps etc to get all of that polish dust out of there (if there is any), then dry, apply sealant/LSP. then stand back and admire your work!
  3. forcefedm3
    do i have to rinse after i clay bar or just wait till after i'm polishing to rinse and wash?
    after i wash the car after polishing, i can apply sealant or wax?
  4. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Yes you can.
  5. TexasTB
    TexasTB Obsessive Detailer
    Wash
    Clay
    Polish (however many times it takes)
    Wax OR Sealant, then wax.
    Never wax then seal.
  6. forcefedm3
    how long do i have to wait to apply the lsp after i polish
  7. PhoTuGo
    PhoTuGo Jedi Nuba
    What if i go from Conilite --> CG Blitz or AW thats fine right
    Technically Connlite is a wax and Blitz is a sealasnt
    But the rule is Most durable on the bottom, but its fine right
  8. MoeJoe12
    MoeJoe12 Virgin Detailer
    Thanks, been here an hour looking for stickies and browsed across this thread. I am no expert and just looking for simple steps as indicated above to clean up my car.
    Thanks TexasTB:worship2:
