STarting a Corporate Carwashing biz and need info
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by gdarnall, Apr 20, 2009.
  1. gdarnall
    gdarnall Virgin Detailer
    First...
    I am going to be doing alot of quickwashing and would like to know a good carwash soap which will be used through my foam cannon to get dirt and grime off, leave the previous wax and polishes on and most importantly LEAVE A GLOSSY, WAX LIKE SHINE WHEN RINSED.
    I am looking into getting Megs SHAMPOO PLUS.
    I am also seeing good things about DuraGloss 901/902, and Majestic SOlutions Ultra Gloss.
    What would you guys recommend overall for cost... clean and shine?
    Second...
    For a good pre-detail soak to get all of the existing LSP's off, what is a a great (not tooo harsh) soap which is not do-or-die with ratios
  2. supercharged
    I recommend that you get a gallon of Citrus wash Clear (foam cannon), Citrus wash and Gloss (bucket), MS Ultra Gloss, and Maybe Shampoo Plus and/or DG 901/902.
    Ultra can be used in a foam cannon, and in a bucket, and will give you a lot of gloss.
  3. JLs Detailing
    If LSP friendly and leaving lots of shine/gloss is what you are after then get a gallon of MS Ultragloss. It leaves the best shine after a wash that I have seen. Like supercharged said it works well in both bucket and foam cannon. It really foams up in the foam cannon.
  4. gdarnall
    greaT ! i have made my decision to go with MS Ultragloss, i appreciate your advice guys!
  5. gdarnall
    and for stripping those LSP's i will get some Citrus Wash Clear ... this is correct ?
  6. JLs Detailing
    That will work for sure.
  7. carguy461
    carguy461 Two Bucket System Washer
    Where do you get the MS ultragloss from?:applause2:
  8. supercharged
    Instead of 2 oz in a foam cannon, use 4 oz...but better off, get some Majestick Solutions Super Green stuff APC...3 oz of that in a foam cannon will strip any sealant off, I'm not even talking about wax...
    Majestic Solutions :: Exterior Products
  9. gdarnall
    thanks again.. just placed my order : )
