Applying wax by hand?
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by Gatorman, Mar 30, 2009.
  1. Gatorman
    Gatorman Virgin Detailer
    I have dodo juice blue velvet that i use on my space grey 3 series bmw.... is it good to apply this hard wax by hand or should i keep applying it with a foam applicator pad? Also if i dont polish my car is it good to use a sealant like Jetseal 109 by CG after claying and before waxing????
    Thanks!
  2. P1et
    It's really whatever you fancy. Doing it by hand is a bit more "exotic" but it makes absolutely no difference. If you have rough hands and you're working on BMW jet black, you've got an issue on your hands. It'll be a bit safer with a foam applicator.
    Yes, you can use Jetseal even if you have not polished, after claying and before waxing.
  3. Hostage1978
    Hostage1978 Guest
    The soft waxes in the Dodo range can be applied by hand with ease, but with the hard waxes, an applicator will do the trick.
    I often layer on a sealant, and once it has cured, apply wax. Paint, whether corrected or not, will benefit from a layer of protection.
  4. Gatorman
    Awesome! thanks guys! Hostage- after the sealant has cured you buff it off before applying wax right?
  5. Hostage1978
    Hostage1978 Guest
    Correct, take off that sealant and lay on that wax!
    Good luck!
  6. spK
    spK DB Forum Supporter
    I'm scared of applying it by hand. MIght induce swirls etc
  7. Nica
    I personally enjoy applying wax by hand, it's a great feeling...well I call it manhandling the vehicle, I personally enjoy applying wax by hand. However, depending on the clear coat you may have no choice but apply via applicator...in all honestly both methods work fine, see what works for you try it out and stick to what works for you.
  8. J BELL
    J BELL Nuba Guru
    Blue velvet is wicked hard...i love applying it because its almost impossible to apply too thick...get you a foam applicator and you will love the app process.
  9. 911Fanatic
    As hostage said, sealant then wax. That way your car will still have some protection when the wax is gone in 6-8 weeks. I'm with Carlos. If I have the time. I like to apply wax by hand because its just cool. Most times however it gets done with a foam applicator pad.
  10. d00t
    d00t Welcome to Detailing
    I also feel like I use MORE product when applying by hand then with an applicator pad.
